Go to Post If your logo is your team number in a font 4" tall in 1/2" stroke, colored/outlined in white, then yes. Otherwise, no. - cadandcookies [more]
Unread 02-06-2003, 14:39
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Brain Persuasion Test
How do you use your mind?
Unread 02-06-2003, 15:31
srawls's Avatar
srawls srawls is offline
#0122 (Nasa Knights)
srawls is an unknown quantity at this point
Send a message via AIM to srawls
Your Brain Usage Profile
Auditory : 68%
Visual : 31%
Left : 50%
Right : 50%
Stephen, your hemispheric dominance is equally divided between left and right brain, while you show a moderate preference for auditory versus visual learning, signs of a balanced and flexible person.
Your balance gives you the enviable capacity to be verbal and literate while retaining a certain "flair" and individuality. You are logical and compliant but only to a degree. You are organized without being compulsive, goal-directed without being driven, and a "thinking" individual without being excessively so.
The one problem you might have is that your learning might not be as efficient as you would like. At times you will work from the specific to the general, while at other times you'll work from the general to the specific. Sometimes you will be logical in your approach while at other times random. Since you cannot always control the choice, you may experience frustrations not normally felt by persons with a more defined and directed learning style.
You may also minimally experience conflicts associated with auditory processing. You will be systematic and sequential in your processing of information, you will most often focus on a single dimension of the problem or material, and you will be more reflective, i.e., "taking the data in" as opposed to "devouring" it.
Overall, you should feel content with your life and yourself. You are, perhaps, a little too critical of yourself - and of others - while maintaining an "openness" which is redeeming. Indecisiveness is a problem and your creativity is not in keeping with your potential. Being a pragmatist, you downplay this aspect of yourself and focus on the more immediate, the more obvious and the more functional.
Eh ... some of it is right on, other parts are not.
Was the site running incredibly slow for anyone besides me?
Stephen
Unread 02-06-2003, 15:33
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Auditory : 31%
Visual : 68%
Left : 55%
Right : 44%
Ed, you are somewhat left-hemisphere dominant and show a preference for visual learning, although not extreme in either characteristic. You probably tend to do most things in moderation, but not always.
Your left-hemisphere dominance implies that your learning style is organized and structured, detail oriented and logical. Your visual preference, though, has you seeking stimulation and multiple data. Such an outlook can overwhelm structure and logic and create an almost continuous state of uncertainty and agitation. You may well suffer a feeling of continually trying to "catch up" with yourself.
Your tendency to be organized and logical and attend to details is reasonably well-established which should afford you success regardless of your chosen field of endeavor. You can "size up" situations and take in information rapidly. However, you must then subject that data to being classified and organized which causes you to "lose touch" with the immediacy of the problem.
Your logical and methodical nature hamper you in this regard though in the long run it may work to your advantage since you "learn from experience" and can go through the process more rapidly on subsequent occasions.
You remain predominantly functional in your orientation and practical. Abstraction and theory are secondary to application. In keeping with this, you focus on details until they manifest themselves in a unique pattern and only then work with the "larger whole."
With regards to your career choices, you have a mentality that would be good as a scientist, coach, athlete, design consultant, or an engineering technician. You can "see where you want to go" and even be able to "tell yourself," but find that you are "fighting yourself" at the darndest times.
Unread 02-06-2003, 18:25
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
Auditory: 50%
Visual: 50%
Left: 61%
Right: 38%
Ashley, you are somewhat left-hemisphere dominant with a balanced preference for auditory and visual inputs. Because of your "centrist" tendencies, the distinctions between various types of brain usage are somewhat blurred.
Your tendency to be organized and logical and attend to details is reasonably well-established which should afford you success regardless of your chosen field of endeavor, unless it requires total spontaneity and ability to improvise, your weaker traits. However, you are far from rigid or overcontrolled. You possess a degree of individuality, perceptiveness, and trust in your intuition to function at much more sophisticated levels than most.
Having given sufficient attention to detail, you can readily perceive the larger aspects and implications of a situation or of learning. You are functional and practical, but can blend abstraction and theory into your framework readily.
The equivalence of your auditory and visual learning orientation gives you two equally effective sensory input systems, each with distinctive features. You can process both unidimensionally and multidimen- sionally with equal facility. When needed, you sequence material while at other times you "intake it all" and store it for processing later.
Your natural ability to use your senses is also synthesized in your way of learning. You can be reflective in your approach, absorbing material in a non-aggressive manner, and at other times voracious in seeking out stimulation and experience.
Overall you tend to be somewhat more critical of yourself than is necessary and avoid enjoying life too much because of a sense of duty. You feel somewhat constrained and tend to sometimes restrict your expressiveness. In any given situation, you will opt for the rational, and learning of almost any type should be easy for you. You might need certain ideas explained to you in order to fit them into your scheme of things, but you're at least open to that!
WOW!.. actually, that's kinda frightening!
Unread 02-06-2003, 19:14
shyra1353's Avatar
shyra1353 shyra1353 is offline
Class of OT9
FRC #0771 (S.W.A.T. (St. Mildred's Women Advancing Technology))
shyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond repute
Send a message via MSN to shyra1353
Auditory : 50%
Visual : 50%
Left : 77%
Right : 22%
Shyra, you are strongly left-hemisphere dominant, with a balanced preference for auditory and visual inputs, a productive combination of traits.
The preeminence of your left hemisphere implies that you are organized, structured, and self-monitoring. You always start analyzing situations and problems by looking at details and then attempt to categorize those details in a very systematic way. You persevere on a theme.
Because of your balance between auditory and visual approaches, you can organize details into a pattern or you can arrange them sequentially so that you have at hand at least two alternatives which dimensionalize your organization and thoroughness.
There is no question that you enjoy a sense of control and feel that planning is important. Everything must be definite since im- provisation is less easy for you. You can be reflective at times and active at others, focus on the visual aspects at some times and on the auditory qualities at others. You have the capacity to simultaneously process a great deal of information and then your tendency is to organize and categorize it as the most convenient mode of accessing it again in the future.
Your balance of sensory preferences tends to make you more perceptive than most, and your ability to organize information adds to your productive processing capabilities.
_______________________________________________
i dont know if i agree with all of that, i mean i know i am not organized, i am one of the messiest people ever (honestly, something falls out of my locker and hits me on the head every time i open it), but some of it is dead on.
2003 : 771 - SWAT - programmer
2004 : 1353 - The Gizmos - founder/team leader - mechanical head
2005 : 771 - SWAT - team manager and captain - design and construction member
2006: 771 - SWAT - mentor
2007: 912 - Iron Lyons - mentor
if you're going around in circles...then maybe you're cutting corners
aim for the moon and if you miss at least you will land amongst the starts
Email: underscore.asdf@gmail.com
My Website!!
Shirts available for trade: 2005 SWAT 771, 2004 Team 1353, 2003 FIRST Canadian Regional, and 2005 Greater Toronto Regional.
I am also interested in operator/safety captain badges, pins, or any other handouts your team may have given out that you would be willing to mail to Canada.
Unread 02-06-2003, 20:37
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Auditory : 68%
Visual : 31%
Left : 50%
Right : 50%
Brandon, your hemispheric dominance is equally divided between left and right brain, while you show a moderate preference for auditory versus visual learning, signs of a balanced and flexible person.
Brandon Martus
e-mail
Unread 02-06-2003, 20:56
Joel J's Avatar
Joel J Joel J is offline
do you..
Auditory : 33%
Visual : 66%
Left : 21%
Right : 78%
..and for some reason it refuses to print my summary. I'll edit the message if I get it to.
[edit]
Could not get the test to display my summary, so I just took the test again.. and surprise, surprise, the results are different:
Auditory : 64%
Visual : 35%
Left : 43%
Right : 56%
joel, you show a slight right-hemisphere dominance with a moderate preference for auditory processing, an unusual and somewhat paradoxical combination of characteristics.
You are drawn to a random and sometimes nonchalant synthesis of material. You learn as it seems important to a specific situation, and might even develop a resentment of others who attempt to direct your learning down a specific channel.
Your right-hemispheric dominance provides a structure that is only loosely organized and one which processes entire swatches of reality, overlooking details. You are emotional in your reactions and perceptual more than logical in your approach, although you can impose structure and a language base when necessary.
Your auditory preference, on the other hand, implies that you process information sequentially and unidimensionally. This combination of right-brain and auditory modes creates conflict, as you want to process data more rapidly than your natural processes allow.
Your tendency to be creative and free-flowing is accompanied by sufficient ability to organize and be logical, allowing you a reasonable degree of success in a number of different endeavors. You take in information methodically and systematically which can then be synthesized rapidly. In this manner, you manage to function consistently well, although certainly less efficiently than you desire.
You prefer the abstract and are a theoretician at heart while retaining the ability to be practical. You find the symbolism in a great deal of what you encounter and are something of a "mystic."
With regards to your lifestyle, you have the mentality which would be good as a philosopher, writer, journalist, or instructor, or possibly as a systems designer or social worker. Perhaps most important is your ability to "listen to your inner voice" as a mode of skipping over unnecessary steps to achieve your goals.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 02-06-2003, 21:12
kristen's Avatar
kristen kristen is offline
PI loves you!
#0639 (Code Red)
Team Role: Human Player
kristen will become famous soon enough
Send a message via AIM to kristen
Auditory : 52%
Visual : 47%
Left : 44%
Right : 55%
Kristen, you are moderately right-hemisphere dominant and have even preferences between auditory and visual processing, traits that might make people perceive you as "slightly off balance."
You are most likely to be slightly disorganized, a "dreamer" and a person who focuses more on the end result than the immediate task at hand. You are creative and spontaneous if somewhat lacking in direction and focus. You are a learner who is generally patient and a person for whom time is an ally, not an enemy.
You are more passionate than most people with regard to life and learning and recognize your own intuitive abilities. You have sufficient goal-direction to satisfy yourself and guarantee success without being or feeling driven. You are willing to be reflective about yourself and others without getting lost in rumination.
The balance of your sensory modes allows for both learning and expressive capabilities achieved by few. You are active and "seeing" while retaining an equally strong propensity for being reflective which slows you down a little but allows for a more comprehensive perception and analysis of situations and problems. You do not spend excessive time analyzing since you mostly trust your perceptions.
In all likelihood, you have a tendency to overcommit and cannot under- stand why others get upset since you operate on a different "time table" than they do. Your organizational abilities are frequently overwhelmed by the stimulation seeking and active nature of your mind as well as by the tendency to create new categories and gloss over details, making categorization and classification almost impossible at times.
To the extent that your career path allows for creativity and abstraction as well as a bit of disorganization, you should find yourself equipped to handle any learning that is required. Your own personal adjustment to your style should come naturally although you are likely to feel frus- trated by your own limited discipline and often wonder "Why?"
HAHA, that actually.. sounds like me. Except I'm way over critical of myself and other people
Unread 02-06-2003, 21:53
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
Auditory : 80%
Visual : 20%
Left : 61%
Right : 38%
Maher, you are somewhat left-hemisphere dominant with a strong preference for auditory processing. This would normally indicate that you are a methodical and efficient person.
You may structure your free time as a way of getting the most out of it, but you are sufficiently loose enough to wander away from your schedule on occasion. Nobody, however, would call you impulsive.
Your auditory learning style is well-fitted with your attention to detail. Those situations where only visual data are provided could be frus- trating to you and your learning curve may go down as your anxiety goes up, unless you have "compensated."
In general you prefer to focus on one thing at a time while learning and give all of your concentration to that. You do not shift gears unneces- sarily and may get frustrated when others do so. Your learning style is very much language-based and logical. In that regard, you concentrate on the functional and the applied aspects of problems or situ- ations. You learn by listening and feel most comfortable in those situations emphasizing logic and consistency. You pace yourself in a consistent manner in both learning and work.
One danger that you might face is that you will over organize and over schedule and thus not generally experience spontaneity, and will lose sight of your own needs. In a similar vein you will not "see" others' needs, but will need them to "tell" you. Even though efficient and organized, you may not feel liked or appreciated. In much the same way, you may need someone to "tell" you to lighten up or look at the brighter side of things.
The overall indication is that you will be steady and reflective, be explicit in your approach to situations and have sufficient flexibility to apply different mental operations in those situations calling for them. You can see the "larger picture" and perceptual process in a simulta- neous way although it is likely that you will then "translate" that experience into a more systematic and unidimensional category for subsequent usage.
That rug really tied the room together...
Unread 02-06-2003, 21:54
srawls's Avatar
Originally posted by Brandon Martus
Auditory : 68%
Visual : 31%
Left : 50%
Right : 50%
Wow ... we have the same brain Brandon! If I were you, I'd be scared
Stephen
Unread 02-06-2003, 22:46
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Auditory: 50%
Visual: 50%
Left: 42%
Right: 58%
Jeff, you are moderately right-hemisphere dominant and have even preferences between auditory and visual processing, traits that might make people perceive you as "slightly off balance."
Jeff Waegelin
Unread 02-06-2003, 22:58
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Auditory : 41%
Visual : 58%
Left : 50%
Right : 50%
Joseph, you exhibit an even balance between left- and right- hemisphere dominance and a slight preference for visual over auditory processing. With a score this balanced, it is likely that you would have slightly different results each time you complete this self-assessment quiz.
You are a well-rounded person, distinctly individualistic and artistic, an active and multidimensional learner. At the same time, you are logical and disciplined, can operate well within an organization, and are sensitive towards others without losing objectivity. You are organized and goal-directed. Although a "thinking" individual, you "take in" entire situations readily and can act on intuition.
You sometimes tend to vacillate in your learning styles. Learning might take you longer than someone of equal intellect, but you will tend to be more thorough and retain the material longer than those other individuals. You will alternate between logic and impulse. This vacillation will not normally be intentional or deliberate, so you may experience anxiety in situations where you are not certain which aspect of yourself will be called on.
With a slight preference for visual processing, you tend to be encompassing in your perceptions, process along multidimensional paths and be active in your attacking of situations or learning.
Overall, you should feel content with your life and yourself. You are, perhaps, a little too critical of yourself -- and of others -- while maintaining an "openness" which tempers that tendency. Indecisiveness is a problem and your creativity may not be in keeping with your potential. Being a pragmatist, you downplay this aspect of yourself and focus on the more immediate, obvious and the more functional
Holy crap, that's scarry...
It's like dead on...
Unread 02-06-2003, 23:10
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
<My comments on this test appear in these brackets.>
Auditory : 29%
Visual : 70%
Left : 42%
Right : 57%
George, you possess an interesting balance of hemispheric and sensory characteristics, with a slight right-brain dominance and a slight preference for visual processing.
<I pride myself on being balanced in all parts of my life. It's nice to have confirmation that my mind is also balanced.>
Since neither of these is completely centered, you lack the indecision and second-guessing associated with other patterns. You have a distinct preference for creativity and intuition with seemingly sufficient verbal skills to be able to translate in any meaningful way to yourself and others.
<Not totally untrue, however I do occasionally have trouble with verbal communication.>
You tend to see things in "wholes" without surrendering the ability to attend to details. You can give them sufficient notice to be able to utitlize and incorporate them as part of an overall pattern.
<Wow. That's quite a compliment.>
In the same way, while you are active and process information simultaneously, you demonstrate a capacity for sequencing as well as reflection which allows for some "inner dialogue."
<Inner dialogue? So that's what those voices are.>
All in all, you are likely to be quite content with yourself and your style although at times it will not necessarily be appreciated by others. You have sufficient confidence to not second-guess yourself, but rather to use your critical faculties in a way that enhances, rather than limits, your creativity.
<Heh. Yes. Even though my beliefs are unpopular I'm very confident in them, and I'm not afraid of what other people think of them.>
You can learn in either mode although far more efficiently within the visual mode. It is likely that in listening to conversations or lecture materials you simultaneously translate into pictures which enhance and elaborate on the meaning.
<True enough.>
It is most likely that you will gravitate towards those endeavors which are predominantly visual but include some logic or structuring. You may either work particularly hard at cultivating your auditory skills or risk "missing out" on being able to efficiently process what you learn. Your own intuitive skills will at times interfere with your capacity to listen to others, which is something else you may need to take into account.
<Hmm... Visual, logical, and structured... Who would have guessed that I'm usually the Strategy Guru of whatever team i'm on.>
<Overall, it was a fairly accurate summary, but the test was utterly agonizing. I get very uncomfortable with ambiguous questions, and this test was full of them.>
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 03-06-2003, 00:54
Breanne M's Avatar
Breanne M Breanne M is offline
Ho Humm... Ho Ho Humm...
AKA: Bree: poor college student
None #0294 (Beach Cities Robotics)
Breanne M is on a distinguished road
Send a message via AIM to Breanne M
Smile almost all true...
Auditory : 52%
Visual : 47%
Left : 50%
Right : 50%
breanne, you are one of those rare individuals who are perfectly "balanced" in both your hemispheric tendencies and your sensory learning preferences. However, there is both good news and bad news.
A problem with hemispheric balance is that you will tend to feel more conflict than someone who has a clearly established dominance. At times the conflict will be between what you feel and what you think but will also involve how you attack problems and how you perceive information. Details which will seem important to the right hemis- phere will be discounted by the left and vice versa, which can present a hindrance to learning efficiently.
In the same vein, you may have a problem with organization. You might organize your time and/or space only to feel the need to reorganize five to ten weeks later.
On the positive side, you bring resources to problem-solving that others may not have. You can perceive the "big picture" and the essential details simultaneously and maintain the cognitive perspective required. You possess sufficient verbal skills to translate your intuition into a form which can be understood by others while still being able to access ideas and concepts which do not lend themselves to language.
Your balanced nature might lead you to second-guess yourself in artistic endeavors, losing some of the fluidity, spontaneity and creativity that otherwise would be yours.
With your balanced sensory styles, you process data alternately, at times visually and other times auditorially. This usage of separate memories may cause you to require more time to integrate information or re-access it. When presented with situations which force purely visual or purely auditory learning, increased anxiety is likely and your learning efficiency will decrease.
Your greatest benefit is that you can succeed in multiple fields due to the great plasticity and flexibility you possess.
Team 294: Beach Cities Robotics
"If I could be the sun, I'd shine in your life. If I could be the rain, I'd rain from your eyes, and I'd wash away the emptiness you feel inside."
~Paul Weller, "As You Lean Into The Light"
"Boys will be boys and so will most middle aged men"
AIM: that13thday
Unread 03-06-2003, 05:55
Hermione692's Avatar
Hermione692 Hermione692 is offline
#0692 (Fembots)
Hermione692 is an unknown quantity at this point
Send a message via Yahoo to Hermione692
yay..looks like my brain is cut out to be an engineer :D
Auditory : 33%
Visual : 66%
Left : 55%
Right : 44%
hermione, you are somewhat left-hemisphere dominant and show a preference for visual learning, although not extreme in either characteristic. You probably tend to do most things in moderation, but not always.
We came (2001), we saw (2002), we conquered (2003)
2003 Sac Regional Champs!!
*****"Mr. Moony presents his compliments to Professor Snape, and begs him to keep his abnormally large nose out of other people's business. Mr. Prongs agrees with Mr. Moony and would like to add that Professor Snape is an ugly git. Mr. Padfoot would like to register his astonishment that an idiot like that ever became a professor. Mr. Wormtail bids Professor Snape good day, and advises him to wash his hair, the slime ball"
White Paper Discuss: 2003 Automated Dead Reckoning Test Code CD47-Bot Extra Discussion 10 07-09-2005 11:25
Extra ramp and platform outside the field at each event to test and practice? Digo General Forum 4 19-01-2003 21:39
Anyone know how to test motors?? archiver 2000 2 23-06-2002 22:21
NEED A BRAIN? archiver 1999 0 23-06-2002 22:07
Test Track- Ride A Thon!! Joe Matt Championship Event 19 14-04-2002 22:53
