Go to Post When it all comes down to it, it's not gonna be the medal around your neck that makes the difference, but the memories that you think about when you look back on how you got there that makes the difference. - Beth Sweet [more]
Go Back   Chief Delphi > Other > FIRST-related Organizations
Unread 15-06-2003, 22:44
blueWarrior's Avatar
blueWarrior blueWarrior is offline
#1049 (Archangel Robotics)
blueWarrior will become famous soon enough
Send a message via ICQ to blueWarrior Send a message via AIM to blueWarrior Send a message via Yahoo to blueWarrior
Beta Testers
We would like to invite testers to download our beta code, run it and find bugs. We want to make sure that all bugs are revealed before the real code release.
If you would like to be apart of this beta testing group then please list your name here. We do not wish to make testing public yet because e are not sure how stable the code.
We only want a small group of people testing the system, then once we make sure that it is stable enough we will then release another testing stage.
During this testing stage we will be accepting patches from the testers.
Your help is much appreciated.
"I'm an angel honestly, the horns are only there to keep my halo up :-p"
Click here for AngelNet
Unread 16-06-2003, 06:28
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
It may be worth mentioning here that read-only CVS access is available for those wishing to be on the 'bleeding edge' of openFIRST development. However, be warned: things in CVS will often break, or do things other than they are intended to do (or nothing at all). Releases that are made available in a more easily downloadable format are generally more stable.
That said, the currently released files are from quite some time ago, and much of the openFIRST system has been redesigned since this time. This means that the Live Demos on the site are the easiest way to test openFIRST software out (the Live Demos use a version that was originally from CVS, but are not currently at the bleeding edge anymore). To access the Live Demos, go to http://openfirst.sourceforge.net and click on modules, then Live Demo beside which ever module you wish to try.
At some point within the next two weeks there will be a new release made on the Source Forge.net file system (exams will be over for all members of the development team as of the end of Friday the 20th). We ask that before this time, testers obtain a CVS version or test using the Live Demo and submit items via the Bug Reports portion of the openFIRST site.
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Unread 16-06-2003, 12:00
apk apk is offline
Hi Everyone, I'm Back.
AKA: Andrew K.
#0104 (Team Universal)
apk will become famous soon enough
Send a message via ICQ to apk Send a message via AIM to apk Send a message via MSN to apk Send a message via Yahoo to apk
I would be willing to help with beta testing.
~Andrew
http://www.team104.com/
Unread 18-06-2003, 15:33
That would be great.
When you ask to test please make sure you list all your server specs.
- Operating System
- Version of PHP/ASP
- Server Name and Version Number
- Basic comp specs
Thanks.
Unread 18-06-2003, 19:48
apk apk is offline
AKA: Andrew K.
I wont be able to get to it right away, but i can test on various systems:
RedHat Linux 9
php 4.2.2 (http://keyes.mine.nu/phpinfo.php)
apache 2.0.40
400mhz
Debian Linux
php 4.1.2 (http://oversoul.mine.nu/~andrewk/phpinfo.php)
apache 1.3.27
Debian Linux
php 4.1.2 (http://www.team104.com/beta/phpinfo.php)
apache 1.3.26
I can test on any (or all) of the above servers. I may also be able to find out more info if needed.
~Andrew
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
PBASIC Editor V 2.0 Beta 2.1 available Lloyd Burns Programming 0 08-07-2003 07:25
White Paper Discuss: HeatWave 2003 Handheld DB (Beta Version) CD47-Bot Extra Discussion 4 07-03-2003 20:22
BETA of the 2000 rules are available V0_0 archiver 2000 0 24-06-2002 00:06
Dashboard Viewer Beta Tester Needed archiver 2000 8 23-06-2002 22:45
