Go to Post Whether we realize it or not, we've all been touched by the works of Dr. Kamen - through his TED talks, through his research and scores of publications in pediatric oncology, or perhaps more directly through his daughter. What an incredible life, what an incredible legacy. - Taylor [more]
Unread 09-09-2003, 18:43
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
WinXP Internet Connection Firewall
Sometimes I need to use external port 80 to serve files or images. However, WinXP has its Internet Connection Firewall on as default (right click connection --> advanced). However, you can edit the settings of what ports you wish to allow access to... FTP/Web Server ports are off by default but they can be turned on and edited... however, for people without a static IP address, this requires editing the IP address every single time. Is there a way around this?
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 09-09-2003, 18:48
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Heh, nm, I figured it out - just type in the computer name instead of IP...
Problem was, under My Computer --> Properties, computer name was "yan." with a period... stupid XP added a period to the end of the name (I was confused but used it anyway) so it didn't work. Eh, someone can delete this thread if they'd like.
How fast is your internet connection? Wetzel Chit-Chat 56 10-10-2003 15:40
