Go to Post I like ice cream. - Andy Baker [more]
Unread 04-10-2003, 11:09
wayne 05 wayne 05 is offline
wayne 05 is an unknown quantity at this point
pwm 13-15
while using the one joystick control code can drive_R and drive_L be used indvidualy like p1_y and p1_x in order to use pwm 13 & 15 indpendently
example: in the one joy stick control code it combides p1_y and p1_x to drive_R and drive_L
drive_r = pwm 13and pwm 15
drive_L = pwm 16 and pwm 14
my motors a on pwm 15 and pwm 13
i want to use pwms 13And 15 for drive motor and no pwms 1and 2
Unread 04-10-2003, 11:58
If I understand your question correctly, yes and its easy to do, there is a simple trick to it.
If you drive the left motor with P1_y and the right motor with P1_x
then all you need to do is turn your joystick 45° on the control panel. (the whole joystick unit, so instead of being oriented like a square, its looks like a diamond)
then, what use to be the upper right corner of the joystick travel will become straight ahead (both motors on full) and what use to be the lower left corner becomes full astern.
the only drawback is the handle on the joystick is rotated, so the buttons are awkward to use.
Unread 04-10-2003, 12:08
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
If I understand you correctly, you want the drive_L variable to be used for both PWM16 and PWM14, and the drive_R to be used for PWM13 and PWM15.
One way you could do this is to place each of those two variables (drive_L and drive_R) into the positions for each of the two PWM outputs in the SEROUT command.
'  Serout USERCPU, OUTBAUD, [255,255,(PWM1),relayA,(PWM2),relayB,(PWM3),(PWM4),(PWM5),(PWM6),(PWM7),(PWM8),(PWM9),(PWM10),(PWM11),(PWM12),(PWM13),(PWM14),(PWM15),(PWM16),(OSC)]
   SEROUT USERCPU, OUTBAUD, [255,255,127,relayA,127,relayB,127,127,127,127,127,127,127,127,127,127,drive_R,drive_L,drive_R,drive_L]
The first line is the example SEROUT that IFI provides in the default 2003 EduRC code, so what I did was place the drive_L and drive_R variables in the string of output bytes where the system will be expecting PWM[13-16]. I set all other PWM values to 127, but you can replace these with whatever you'd like.
I hope this helps. If I misunderstood the question, I blame the fact that I just woke up...
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
Ugh...PWM pin vs. Speed Controller archiver 2001 1 24-06-2002 00:27
Loss of signal in PWM cables. archiver 2001 6 23-06-2002 23:29
PWM Wires... Anton Abaya Technical Discussion 3 04-02-2002 05:07
