Go to Post Give me enough gearboxes and I'll move the world. - SenorZ [more]
Unread 02-02-2002, 09:47
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
Working Pump Code
I need a working pump code, fast. Can anyone post a real working copy? Thanks in advance.
-Dan
Unread 02-02-2002, 11:30
jnossen jnossen is offline
jnossen is an unknown quantity at this point
'Place this in the main loop
gosub Comp_Switch:
'Place this below the main loop
Comp_Switch:
if rc_sw2 = 0 then low_pres: 'Compressor switch
comp_on = 0 'counter variable
relay1_fwd=1
relay1_rev=0
return
low_pres:
if(comp_on = comp_off) then compress_off: 'comp_off is set
'to 120. try other
'values to see which you like.
'Still not sure whcih value we'll use
relay1_fwd=1
relay1_rev=0
comp_on = comp_on + 1
return
compress_off: 'Deactivate Compressor
relay1_fwd=0
relay1_rev=0
return
Hope it helps. This assumes that you are going into digital inputs 2 and 6.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
pneumatic wiring nick_champ_2 Electrical 3 23-02-2003 01:21
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
