Go to Post Use these tools as a starting point, not as an end product. - Tom Bottiglieri [more]
Unread 24-11-2003, 08:24
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
help with Interrupts
Basically i learned that the PIC18 we are using has digital interrupts, how do we use them. Because so far i understand that when the digital interrupt is triggered it stops the main program and goes to address it. Where in the program or how do we specify that which interrupt should result in what procedure. If some canhelp me here it will be great
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 24-11-2003, 11:46
Kevin Watson's Avatar
La Caņada High School
FRC #2429
The function that is called in response to an interrupt is specified in "user_routines_fast.c". If there is some interest, I could whip-up some example code that uses interrupts and timers.
-Kevin
Kevin Watson
http://kevin.org
Unread 24-11-2003, 12:23
InnovationFirst's Avatar
InnovationFirst InnovationFirst is offline
Official FIRST Supplier
InnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond reputeInnovationFirst has a reputation beyond repute
For good general pointers on how to use interrupts, see IFI's white paper titled Using Polled or Interrupt-driven Timers at: http://www.innovationfirst.com/first...ite_papers.htm
It does not specifically address using the external interrupt pins (labeled INTERRUPTS on your EDU RC), but the principles for using external or internal (i.e. timer) interrupts are the same.
For more information on configuring your INTERRUPTS pins for use with interrupt-driven code, read the Microchip PIC18FXX20 Data Sheet. General interrupt information is on pages 87-102. Note that by checking ifi_aliases.h you can find out the mapping of the microcontroller pins (RB2-RB7) to the INTERRUPTS pins. Specific information on these pins and their interrupts is on pages 106-108 of the data sheet.
As a final note, remember that all interrupts that you use MUST be low priority. If you try to make any interrupts high priority then you will see the PROGRAM STATE LED blinking red.
Unread 08-01-2004, 15:29
WizardOfAz's Avatar
WizardOfAz WizardOfAz is offline
Lead Mentor
AKA: Bill Bennett
FRC #1011 (CRUSH)
WizardOfAz will become famous soon enough
Send a message via AIM to WizardOfAz
PROGRAM STATE LED is red
When else can the PROGRAM STATE LED turn red? I get it sometimes when not doing anything with timers or interrupts, and haven't yet figured out why.
Stack overflow for example?
Thanks,
Bill Bennett
Unread 08-01-2004, 16:07
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
Re: PROGRAM STATE LED is red
Thanks,
Bill Bennett
If too much current is given or too high of a voltage? Couldn't tell but it was flashing red. :-)
Invalid code did it once, sent an empty program to eduRC.
Accessing an invalid ptr and making reference to it.
Those are the only three I've gotten.
Thanks,
Ryan Waliany
R
Unread 24-11-2003, 17:49
thoughtful's Avatar
Hey guys thnx a lot for your help, and i will love to see somw examples Kevin.
06-Team 1219 Mentor
Interrupts on the EDU-RC? Andrew Programming 3 13-11-2003 23:16
New Controller Specs Posted Jnadke Programming 58 05-10-2003 08:18
New Controller programmable in C dez250 Programming 48 02-10-2003 19:28
What is an interrupt handler? Adam Y. Programming 7 14-08-2003 10:26
Possible Configuration to keep things cheap archiver 1999 8 23-06-2002 23:03
