Go to Post So many possibilities so many different meanings and soo many different opinions. LOL but i guess this is what FIRST is all about. - Bcahn836 [more]
Unread 16-12-2003, 11:57
Melissa Nute's Avatar
Melissa Nute Melissa Nute is offline
I like my hammer...
Melissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond reputeMelissa Nute has a reputation beyond repute
Send a message via AIM to Melissa Nute
Theatre Stages
I am in the process of writing a theatre paper at school about set design. Well...actually a letter to a set designer advising him with what to do. (Silly IB assignments)
I am discussing the use of a mawari butai (revolving stage); however, I decided to make it mechanical instead of the traditional use of stage hands underneath the stage. My mawari butai is on top of the existing stage. Basically, my point is I am trying to figure out how to describe exactly how to build a gear-motor system that will be able to support such a revolving stage and more so exactly what type of motor to use for this.
Unread 16-12-2003, 12:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Theatre Stages
First of all, the motor will not support the stage. Something else will have to. I know casters suck but for this application several of them all over may be the way to go; with a large axle sort of something for the center of the circle. Excatly how much is this going to weigh when it's built and people and stuff are on it? Also, how big will it be? If it only needs to go one way, you can probably pick up a large AC motor at some sort of surplus store. It shouldn't be too hard to find one with a standard keyed output shaft. Something like this maybe http://www.harborfreight.com/cpi/cta...emnumber=30188 You can also search harborfreight for "motor" and see the other ones. You will have to gear it down quite a ways.
Unread 16-12-2003, 12:56
I like my hammer...
Re: Theatre Stages
I know the motor does not support the stage...but its power will affect the turning of it. The purposed weight will be almost 4000-4500 pounds that will have to be supported. The design of the top of the mawari butai is almost 13 feet in diameter.
Unread 16-12-2003, 13:35
Jason Rudolph Jason Rudolph is offline
Alumni of 168
Jason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud of
Send a message via AIM to Jason Rudolph
Re: Theatre Stages
Wow, someone actually asking about theater on this board, something I never thought I'd see. Anyways, here is a good company to try and contact, some of their installations are pretty darn cool. They might be able to help you out.
http://www.macton.com/
QUESTION OF THE WEEK!!! archiver 2000 34 24-06-2002 00:07
Pits were great, venue was the pits... archiver 1999 17 23-06-2002 22:44
Two Stages What's UP With That?????? archiver 1999 0 23-06-2002 22:37
Number of Stages archiver 1999 7 23-06-2002 22:21
