Go to Post You might even learn something! - Tom Bottiglieri [more]
Unread 04-02-2002, 19:35
rdmendola rdmendola is offline
rdmendola is an unknown quantity at this point
Question shaft coupling
We have a problem with our drill couplings that we bought from SPI. We have installed them -- drilled and put a pin in as instructed -- and they are not true. Has anyone else experienced this? Does anyone have any advice?
Unread 04-02-2002, 19:50
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
We had zero problems with the SPI couplings.
We used a 1/8" keyway on the drive shaft to mate with the keyway in the coupling and a 1/16" Steel roll pin on the drill motor shaft (threaded end) as specificed by the SPI documentation.
We have not experienced any problems and have been testing (beating up) the drive train for about 1 week now.
We should be ready for FULL bot testing (read FULL WEIGHT) within the next 2 days. I'll be sure to post any problems if they arise.
Unread 04-02-2002, 20:57
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Re: shaft coupling
Not sure what your problem is, "and the are not true", but let me take a guess.
Are you talking about the hole size and pin size are different? The pins SPI shipped with the couplings are 1/8" and the hole on the coupling is actually 1/16". You will have to use the 1/16" hole as pilot hole, and fit the 1/8" dowel pin in instead.
Other than that, I can't imagine any other way they can be wrong... The couplings should screw on drill motor output shaft just fine, and the other should be able to fit in a 3/8" shaft. If you have the right keyway on the shaft, you can match up with the keyway on the couplings' other end, and put in a 1/8" by 1/8" key.
If you are experience problem with screwing in the coupling into the drill shaft, or fitting in the 3/8" in the other end, try using the allen wrench that came with the package to unscrew the socket headed screw on the side a little bit, although you would want to tighten them after you install everything.
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
Big Shaft to Little Shaft? Anton Abaya Technical Discussion 7 21-01-2002 19:27
3.5x3.5 coupling? ahecht Technical Discussion 1 05-01-2002 23:36
