Go to Post While we discuss this stuff, let's keep our heads on straight. Open your eyes and look around you. Let's celebrate our common goal while accepting our differences. - Andy Baker [more]
Unread 18-12-2003, 12:19
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Redimensioning in AutoCAD
Is there an easy way to redimension something in AutoCAD? Will the redimension show up as a permanent change or is it just for blueprints?
I'm trying to make a solid model using a wax based rapid prototype machine, but wax has a tendency to not like press fitting. Therefore, I need to change the dimensions of a number of shafts and holes by a few hundredths of an inch.
Thanks,
indieFan
Unread 18-12-2003, 12:32
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Arrow Re: Redimensioning in AutoCAD
Most likely, you're going to need to change the actual geometry, since dimensions aren't linked to the geometry components of the drawing.
AutoCAD is unique in that it's not a constraint based CAD package, every entity is independent... dimensions are set to points, not geometry. Once you change the geometry you'll most likely have to redimension everything you changed.
Sorry for the bad news.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 21-12-2003, 02:08
Elgin Clock's Avatar
FRC #0237 (Black Magic)
To really answer this question I would have to know what version of AutCAD you used, and how you drew it.
If you used AutoCAD 14 or below, then you have to do like Matt stated, and redraw the geometry.
Now if you used AutoCAD 2000 or above, or even a Mechanical Destop product - MDT5, MDT6 or MDT2004, and if you created the geometry correctly and made it 3d, and extruded it, then more than likely the dimensions are "parametric" and you can just change a dimension and the geometry will change.
AutoCAD products (with the exception of Inventor) are still on the edge in that way. They are not a true parametric product yet like Solidworks and it can be used to make just 2d sketches, or 3d models.
Side note:
What kind of rapid prototype system are you using? I used a Rapid Prototyping system from Z-Corp but that was basically starch and glucosed based to make the parts.
Unread 22-12-2003, 16:13
FRC #5941
Well, I used AutoCAD 2002 to draw the part. Essentially, I drew a circle of 0.25" diameter and then extruded the circle. Whether or not that changes it to a 3D or not, I have no clue. (I'll have to read the book as my prof. never discussed that stuff with us.)
As for the RP machine, it's a 3D Systems ThermoJet. Easy removal of the support structures, but no so easy to mate two parts that are "identical" in size. (ie, 1/4" bearing to 1/4" shaft)
indieFan
Unread 08-01-2004, 16:08
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
this is y i love inventor
Unread 08-01-2004, 16:55
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
indieFan
The basic problem is probably two fold.
First, for rapid prototypes you need to plan your gaps just as you would when making metal parts. So if you want to put a bushing on a shaft, for example, you need to make sure that the hole in the bushing is slightly larger than the shaft. So if you have a shaft that is precision ground to be 0.250 + or - 0.001 then your minimum hole diameter should be something like 0.252. Press fits are a slightly different story, but I probably wouldn't press fit anything made of wax.
If you accounted for this in the design, then you still have the issue of the .stl file used to build the prototype. STLs are approximations of the shape of you part composed entirely of planar triangles. Curved surfaces (like the inside of a hole) are approximated by a bunch of triangles connected together. That's why holes produced by Rapid Prototyping machines aren't round, they are polygons. So you also need to allow for the fact that round things will not be round, nor will their diameter be constant around the part
With some converters you can control how big the "chordal tolerance", the distance between the triangle and the cad model surface , can get. Other converters use a fixed number for this and if it's too big you get huge facets and an ugly looking part. For my work I like to use a maximum chordal tolerance of 0.003 in. Sometimes I have to take it down to 0.001 to get good results. But one of the CAD systems I use has a fixed value of 0.010".
So the answer to your problem may be to simply retranslate with a much smaller chordal tolerance. Also be aware that most rapid prototype systems have tolerances on the order of +or- 0.005in/in. So if you want things to fit together you often need to allow substantial gaps between parts, like 0.010-0.020 in. or more
On the other hand RP machines are pretty fun to work with. I like loading the file in the afternoon and having the part the next day, exactly as I designed it. Of course then there's no opportunity for the machinist to point out your mistakes before the part is done either
OOPS time to go back downstairs and finish glueing the SLS (another rapid prototype method) mold I made together. The glue from the previous joint should be set by now.
Christopher H Husmann, PE
"Who is John Galt?"
AutoCAD Drawings Brandon Martus OCCRA 35 15-10-2002 11:33
AutoCAD Viewer Gadget470 OCCRA 2 25-09-2002 03:19
Help with Autocad and Bryce 5 Keith Chester Inventor 0 25-03-2002 17:33
AutoCAD, Inventor, or Other D.J. Fluck General Forum 23 31-12-2001 08:59
AutoCAD 2002 David Kelly Inventor 7 24-06-2001 09:11
