Extracting Individual bits in C
Since I didn't know how to do this, I thought some people might want to know.
First off, the code: Code:
int some_var=5; /* the variable we will be extracting a bit from. */ int n=3; /* the position of the bit we want */ the_bit = (( some_var & (1 << (n-1) ) ) ? 1 : 0 ); Yes folks, a left shift, some binary logic, and the ternary operator, all in one line! looks impressive, huh? (Does anyone know if the PIC supports the ternary operator? if not, it's simple to convert to an if-else, but this is so clean! ) Now, some explanation: We'll start by talking about the << operator. This shifts whatever is to it's left of to the left the number of places given by the expression on it's right. In the code above, it shifts 1 left by 2 (n-1 = 3-1 = 2) places, filling spaces on the end with zeroes. This gives us 00000001 => 00000100 (assuming an 8 bit int, didn't check how large an int on the PIC is, but it doesn't matter for the point of this demonstration) An expression like this is known as a mask, and can be used with the & operator to test a single bit. Now you see that we compare the mask (1 << (n-1) ) with the variable to be tested using the binary bitwise and operator (&). It checks each bit place in each string against each other. Any place where both digits are 1 evaluate to 1. All other places evaluate to zero. So, what we are really looking at in the example is (00000101 & 00000100) Which will evaluate to (00000100) Now, we plug this value (4) back into our ternary expression. Time for a quick lesson in ternary! The ternary operator ? looks at the expression that precedes it. If the expression is true, the expression following the operator is evaluated. If it is false, then it ignores code until it reaches a : . It then procedes to evaluate whatever follows the colon. In our example, we get an expression that looks like 4 ? 1 : 0; Four is non-zero, so it evaluates to true. This means that the statement evaluates to 1. So, in our example, Code:
printf("the_bit: %d", the_bit);
OUTPUT:
the_bit: 1
the_bit = (( some_var & (1 << (n-1) ) ) ? 1 : 0 ); First we create a mask with a 1 in the place of the bit we want to find and zeroes elsewhere. The zeroes elsewhere mean that the & on those bits will always evaluate to zero. The real comparison, therefore, only takes place on one bit, somevar.bit[n]. If this bit is one, then the expression returns a non-zero value, which is true, which then returns one from the ternary. If this is false, then the whole thing works out to zero, or false, so the ternary evaluates to 0. And there you have it folks, how to fetch bits in c. |
Re: Extracting Individual bits in C
You could round out the set by providing macros to set a bit value and clear a bit value. This would be useful if you have a byte with individual flag bits. var is a value and bit is the bit position you're working with. Bit 0 is the least significant bit (on the far right-hand side).
//get a bit from a variable #define GETBIT(var, bit) (((var) >> (bit)) & 1) //set a bit to 1 #define SETBIT(var, bit) var |= (1 << (bit)) //set a bit to 0 #define CLRBIT(var, bit) var &= (~(1 << (bit))) Dave had a good point, added parens around arguments. Left the parens out of SETBIT and CLRBIT since var needs to be a left hand argument. Will leave the conversion to functions to you all, but logic is the same. We have a union to match the PBASIC BYTE variable type that is bit-addressable. Its not portable but works with the PIC controllers. You can pull out the 8-bit value using the byte field or get a single bit using b0 - b7. Makes a handy way to track a set of flags. Code:
//byte, addressable bits
//size: 8 bits (1 byte)
//range: 0 to 255
typedef union {
struct {
unsigned b0:1;
unsigned b1:1;
unsigned b2:1;
unsigned b3:1;
unsigned b4:1;
unsigned b5:1;
unsigned b6:1;
unsigned b7:1;
uchar byte;
} byte;
Sean
You have a good suggestion to make these macros. They seem to work to perfection, however, there is a common error that you made. When writing macros, it is a good idea to surround your arguments with parenthesis in the definition. Let's walk through this example Code:
#define PI 3.14 #define CIRCLE_AREA(r) (PI * (r) * (r)) area = CIRCLE_AREA(4) Code:
area = 3.14 * (4) * (4) Code:
area = CIRCLE_AREA(i+2) Code:
area = 3.14 * (i+2) * (i+2) Code:
#define CIRCLE_AREA(r) (PI * r * r) area = CIRCLE_AREA(i+2) Code:
area = 3.14 * i + 2 * i + 2 Code:
area = (3.14 * i) + (2 * i) + 2 On a side note, I try to use functions instead of macros when efficiency is less critical or when the routine to be run is complex. Now, I don't want to get into a whole debate about macros and functions, because each has their place. I find that it is easier to debug functions than macros because you can step through them in a debugger. |
Example: Try to access the 3rd bit of 20. 20 = 00010100 00010100 >> 3 == 00000010, but 00010100 >> 2 == 00000101, yielding the correct digit in the correct place. However, without the ternary operation here, you are likely to return a number of non-binary answers: as you just saw, running GETBIT (20, 3) would yield 2 as you have it written, or five after the (bit-1) correction. One other correction: The comments you used are C++ style, and not valid in C. watch out! I believe that corrected macos follow: Code:
/* get a bit from a variable*/ #define GETBIT(var, bit) (( var & (1 << (bit-1) ) ) ? 1 : 0 ) /* set a bit to 1 */ #define SETBIT(var, bit) (var |= (1 << (bit-1))) /* set a bit to 0 */ #define CLRBIT(var, bit) (var &= (~(1 << (bit-1)))) |
Also, GETBIT cannot return 2 or 5, it can only return 0 or 1 since 'AND'ing anything with 1 will get rid of all but the least significant bit. Last edited by Mike Soukup : 08-01-2004 at 13:10. |
Efficiency of underlying asm code
Hey, can anyone give me an idea about the relatative effeciency of the underlying assembly language code for using the shifting macros vs. using the union/structures method?
I suppose that most times the code ends up more or less identical but I wonder on this particular CPU with this particular compiler, if there is a major advantage one way or the other. My main reason for asking is that I am dreaming about 100 million things I want to do in the interrupt service routine (ISR), 88 million of them involve such bit piddling, not being one who likes to stack up ISR upon ISR upon ISR, I am concerned about effeciency of the code that does these things. Your comments welcome... Joe J. Last edited by Joe Johnson : 08-01-2004 at 13:13. Reason: typos, typos, everywhere... |
#7
Re: Efficiency of underlying asm code
First, the union method: Code:
typedef struct bits {
unsigned char b0:1;
unsigned char b1:1;
unsigned char b2:1;
unsigned char b3:1;
unsigned char b4:1;
unsigned char b5:1;
unsigned char b6:1;
unsigned char b7:1;
} BITS;
typedef union bit_char {
unsigned char byte;
BITS b;
} BIT_CHAR;
main ()
BIT_CHAR test1;
test1.byte = 5;
test1.b.b2 = 1;
000802 cfd9 MOVFF 0xfd9,0xfe6 000806 cfe1 MOVFF 0xfe1,0xfd9 00080a 52e6 MOVF 0xe6,0x1,0x0 00080c 0e05 MOVLW 0x5 00080e 6edf MOVWF 0xdf,0x0 000810 84df BSF 0xdf,0x2,0x0 000812 52e5 MOVF 0xe5,0x1,0x0 000814 52e5 MOVF 0xe5,0x1,0x0 000816 cfe7 MOVFF 0xfe7,0xfd9 00081a 0012 RETURN 0x0 Code:
#define GETBIT(var, bit)(((var) >> (bit)) & 1)
//set a bit to 1
#define SETBIT(var, bit)var |= (1 << (bit))
//set a bit to 0
#define CLRBIT(var, bit)var &= (~(1 << (bit)))
main ()
char test1;
test1 = 5;
SETBIT(test1,2);
000802 cfd9 MOVFF 0xfd9,0xfe6 000806 cfe1 MOVFF 0xfe1,0xfd9 00080a 52e6 MOVF 0xe6,0x1,0x0 00080c 0e05 MOVLW 0x5 00080e 6edf MOVWF 0xdf,0x0 000810 84df BSF 0xdf,0x2,0x0 000812 52e5 MOVF 0xe5,0x1,0x0 000814 52e5 MOVF 0xe5,0x1,0x0 000816 cfe7 MOVFF 0xfe7,0xfd9 00081a 0012 RETURN 0x0 |
#8
| Sweet Repeat Bits | skrussel | Off-Season Events | 0 | 09-10-2003 21:13 |
| Applying Material to individual Faces | k_kurutz | 3D Animation and Competition | 4 | 07-01-2003 15:36 |
| Microsoft's dominating power | Kyle Fenton | Chit-Chat | 18 | 29-08-2001 13:06 |
