Go to Post The kick-off is your opportunity to finally open the REALLY BIG box that has been sitting under the tree. - dlavery [more]
Unread 10-01-2004, 18:57
Greg Powers Greg Powers is offline
#0814 (MegaForce Squadron)
Greg Powers is on a distinguished road
Exclamation alternating between matches!
With the chutes taking up so much space there is only 2 spaces for controlers which means much more in-between-match-time
I'd hate to think FIRST overlooked this crucial detail, its going to take a lot of extra time.
Sincerely,
ME
Unread 10-01-2004, 19:00
BandChick's Avatar
BandChick BandChick is offline
Superpower: Knows Everyone
AKA: Sara Reffler
FRC #1089 (Team Mercury)
BandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond reputeBandChick has a reputation beyond repute
Send a message via AIM to BandChick
Re: alternating between matches!
my guess is that there is still that shelf space, and how long does it really take to remove your controller system and hook in the new one?
2016 Championship userbars are here!
1089 Mentor & Alum | 2016 MAR Championship Finalists, Innovation in Control Award Winners
2015 Archimedes Champions | 2015 Einstein Semi-Finalists
2014 MAR Championship Finalists | 2014 Bridgewater District Finalists | 2013 Lenape District Finalists | 2011 NJ Regional Finalists
2014 & 2015 Excellence in Engineering Award | 2014 Xerox Creativity Award
2009, 2011, 2013 KCP&B Entrepreneurship Award Winners | 2012 Gracious Professionalism Award Winners | 2009 NJ Regional Chairman's Award Winners
"Success in life is a matter not so much of talent or opportunity as of concentration and perseverance." C.W. Wendte
Unread 10-01-2004, 19:15
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
I am also wondering about this. It is going to take time to lower the bar, unhook robots, and then raise the bar again. While this is going on, there will be ample time to set up controls and robots, I would think. But This could mean 5 minutes between matches. Previously matches could begin every 5 minutes, not every 7-8 minutes. Maybe it'll go quicker than I think...hard to say. But in this case, teams ultimately end up with less qualifying matches, which in the case of the larger regionals like Chicago and Cleveland and Great Lakes, that could mean only 5-7 matches for qualifying....
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 10-01-2004, 19:19
BandChick's Avatar
AKA: Sara Reffler
well, i'm not positive, but didn't woodie make the lowering of the bar out to be a safety issue? like only if absolutely necessary?
Unread 10-01-2004, 19:20
iCHiMaHoCV iCHiMaHoCV is offline
iCHiMaHoCV is an unknown quantity at this point
That is what he said, if teams decide to design their robots so that they can hang then I certainly hope that they think far enough in advance to have a way to easily unhook the robot from the bar.
Unread 10-01-2004, 19:22
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I suppose the reasoning is that they dont want to have teams needing to reach over their heads to grab a robot that is like 5+ feet in the air, possibly. Also, its going to be impossible to reach anything grasping the top bar to release it, without it being lowered.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 10-01-2004, 19:25
The rules say that as long as the robot is NOT touching any part of the field other then the pull-up bar then it counts, so it could be only an inch or two off the field and it would still count and it would be a lot easier to remove the bot if its only an inch or two off the ground.
Unread 10-01-2004, 19:29
Cory's Avatar
AKA: Cory McBride
the *robot* will be 2' off the ground, but whatever youre going to be attaching to the bar with will be 10' off the ground. Unless you know Paul Bunyan, I dont think you can reach that high to disengage whatever mechanism youre using.
Cory
2001-2004: Team 100
BandChick's Avatar
AKA: Sara Reffler
yes, but it's not a matter of getting back onto the ground so much as it is getting it off the bar. if there isn't a way to release the arm or whatever attachment simply and there is a chance of human injury, then the bar would serve a purpose. so people, think about this now, design so you don't get hurt, because that would just be messy!
Unread 10-01-2004, 19:31
In response to Cory:
That is true, but if you just have a hook then if the bot is only 2 inches or so off the ground then its easy to get a hold of the bot and just lift the bot then drop the bot to the ground. But if you DO have something that latches or a grappling hook type thing then I can see some trouble with that unless its really well thought out.
Unread 10-01-2004, 19:21
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
That seemed to be how they were presenting it. I think the goal is to have teams take their controller over with a tether and manually let their robot down. If that won't work, that would be when the lowering the bar comes into play.
But one of the ideas that they presented via the animation video of the game was that you could have an arm that would grab and lift your robot. So its very possible that many teams will decide to make a hooking arm.
2003 matches played shyra1353 General Forum 5 12-11-2003 20:20
11 matches played... ...some thoughts... Joe Johnson Regional Competitions 16 08-03-2003 10:29
Re: Trying not to seed.... (same wish) archiver 2001 8 24-06-2002 02:36
Throwing matches archiver 1999 4 23-06-2002 22:17
What is the length of time between Qualification matches? Randy_Ai Rules/Strategy 2 21-01-2002 16:47
