Go to Post Oh great, look what you just did. The GDC will probably find ways to use this to torture teams in 2011. I hope you're happy now. - synth3tk [more]
Unread 06-02-2002, 20:46
SiliconKnight's Avatar
SiliconKnight SiliconKnight is offline
#0824 (SWAT Robotics)
SiliconKnight is an unknown quantity at this point
Send a message via ICQ to SiliconKnight Send a message via AIM to SiliconKnight Send a message via Yahoo to SiliconKnight
Bicycle Cables Anyone?
Hey, I was just wondering if any of you have checked to see if bicycle cable is legal. Some people on our team think it might be legal because it's just basically steel cable that is covered, but some of us disagree. Thanks!
Unread 06-02-2002, 20:51
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Bicycle cable, as in the brake cable?
Viva Olancho!
Unread 07-02-2002, 06:22
Pat Sarmiento Pat Sarmiento is offline
#0254 (Cheesy Poofs)
Pat Sarmiento is an unknown quantity at this point
Send a message via AIM to Pat Sarmiento
I'd think it would depend on what you plan to use it for. There's that 'risk of entanglement' rule, bike brake cable might still do that...
Email FIRST, see what they think. I'm not sure myself.
Unread 07-02-2002, 15:33
Andy A. Andy A. is offline
Getting old
FRC #0095
If you can find bike cable (or something like it) in small parts or on the addparts list, you can get it. My assumption is that you can find it in small parts.
if it poses a risk of entanglement or not, that depends on how you use it and what the judges think. As long as it's not 'exposed', as in it's not on the outside of the 'bot, and you ziptie it down or something, you shouldn't have any problem.
Be aware though, I've always found bike cable to be very annoying. If you plan on using it, keep it covered! The cable frays and seperates very easily if not. Remember that it's not terribly strong to start with, any fraying or nicks in it makes it very weak.
-Andy A.
Unread 11-02-2002, 13:55
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
Also beware if you are planning on using that to shift some sort of transmission. Like a bike maybe? Have you ever tried to shift your bike while you are pedaling up a hill? It will not work.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
Unread 26-01-2003, 05:56
AFAIK, it'll fall under the $3.5k discretionary funds rule. No, we'll use it for control cabling. It would work great.
There are ways to design around why you can shift a bike paddling up hill (actually, that's not true too - I routinely shift, both ways, going up hill. you just have to have good technique )
A bicycle upshifts by using lifter ramps punched / machined into the chain ring. During a hard climb, chain tension will override the lifting force that these lifter ramps can generate to pop the chain from small gear to large gear (the derailer only moves the chain laterally, it cannot generate the force to lift the chain up one cog). So, the trick is you pedal faster than you would need, then drop your pedal speed while the bike is still coasting and simultaneously hit the shifter. Try it.
-=- Terence
Can we shorten the PWM cables? RAWdealer59 Electrical 3 18-02-2003 15:49
FOR SALE: Long serial cables Cheap!!! sanddrag General Forum 10 06-11-2002 15:39
maximum length of joystick cables archiver 2001 2 23-06-2002 23:54
Loss of signal in PWM cables. archiver 2001 6 23-06-2002 23:29
No cables? archiver 2000 5 23-06-2002 22:43
