How many Pneumatics pistons can we use?
Does any one know how many Pneumatics pistons we are aloud to use
Re: How many Pneumatics pistons can we use?
in years past, it was 3 @ 60psi
i believe this year we can use up to 4 running @ 120psi someone correct me if im wrong |
from the "robot" section of the rules manual, section 5.2.9, Pneumatics System Requirements, rule R54, bullet #3:
![]() As for pressure, you can have 125 psi in the tanks, but still only 60 psi working pressure. Quote:
Last edited by RoboCoder : 11-01-2004 at 21:30. Reason: wanted to answer both questions in 1 post instead of 2 |
You can only have 120 PSI in your accumulators, to clarify. What the rule really says is that all components must withstand 120 PSI of pressure.
Cory |
Actually, the cylinders can only be run at 60 psi, (after the air has gone through the regulator). When buying components, FIRST wants all teams to buy equipment that CAN take 120 psi, as a safety issue in case of a failure. That is why they say "off the shelf" pneumatic devices must be "rated for" at least 125 psi, but "working pressure" is a maximum of 60psi. So, if your equipment is designed to handle 125 psi, and you're only using 60 psi (according to the rules), then the chance of having a failure of the equipment itself is significantly decreased. So, 120 psi in the tanks, then the regulator which knocks it down to 60, then your solenoids and cylenders that use the 60 psi. Hope this clarifies.
Those last two posts seem to conflict with each other. I think I can clarify. Storage tanks which connect to the pump upstream of the Norgen regulator (the one set to 60 psi) can have 120 psi. This is not "working" pressure, it is the storage. The rest of the system downstream in the working section is 60 psi. I am referring to the pressure used, not the capability of the products used.
As always, if I'm horribly wrong, forgive me and correct me. Hope this helps. Good luck to all! |
| pneumatics | adamoneDB04 | General Forum | 1 | 28-01-2003 11:59 |
| Pneumatics hose | Brett W | Kit & Additional Hardware | 10 | 09-01-2003 15:35 |
| What are pneumatics? | Aignam | Pneumatics | 23 | 16-10-2002 21:17 |
| pneumatics tank | archiver | 2000 | 2 | 23-06-2002 22:43 |
| Should all three pneumatics pistons have been received? | Jordan A. | General Forum | 6 | 08-01-2002 13:48 |
