Go to Post As mentors we need to be good role models for students. Because like it or not, we will be role models. - mathking [more]
Unread 12-01-2004, 11:02
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Problem with Lowering the Bar
One thing FIRST might have overlooked:
The bar can be lowered after a match so that robots can be removed easily. If you have just a hook, you can lift your robot straight up and carry it (which will be very awkward) off the field. Then you can tether and lower it to fit through doorways and such. If you have a locking mechanism on your hook so that you can't be knocked off the bar (a simple spring latch), you can't reach it to open the latch and lift your robot. The bar is lowered to where you can reach it...but if your robot is only a couple of inches off the ground, that bar can't be lowered more than a couple inches. The whole system would get jammed and either ruin the mechanism, the robot, or both.
The simple solution is to swing your robot around the bar so the bar can be lowered - this will take at least three people per robot (two to hold the robot steady, one to release the mechanism and catch that half of the robot) which is not a big deal. If there are 4 bots on the bar and on top of one another in a big mess, this is going to take time to sort out and get taken care of. Here is where the problem comes in. If your robot is only off the ground an inch or so, there will most likely (depending on the position of the hook relative to the robot - edge or middle) not be enough rrom to swing your robot clear of the platform. If there is one bot like that, there could be other bots stuck 3' off the ground. Now we have to find ladders and take great care not to fall off the ladder, not to get crushed by the robot, and whole mess of other things. I'd say this situation won't be common, but you never know.
NOTE TO FIRST: Have ladders on hand at the arena!
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 12-01-2004, 12:36
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
Re: Problem with Lowering the Bar
Note to teams designing a mechanism such as the one described above:
Design your locking mechanism so that it may be unlocked by someone standing on the ground via pulling a string, or other method which does not require the robot to be enabled.
-Joel
Unread 12-01-2004, 12:47
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Perhaps an update mandating the prevention of such occurance is in order? It is possible that rookie (and likely veteran teams also) could overlook this possibility and have a rigid structre.
I think the FIRST crew needs to make sure that everyone knows about this, not just readers of CD.
Unread 12-01-2004, 14:53
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
I'd have to agree with what's been said.
It would be a very good idea if FIRST also publishes this in an update.
Just as in 2002, if you couldn't detach your robot from the goals, you got DQ'ed. If you design your robot this year so that it can't use the bar-lowering to release it, well then.. that wasn't very good engineering now was it?
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 12-01-2004, 14:59
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
either design a sting release mechanism, avoid this system, or make a collapseable "arm" since the bot and only be 60" tall, it needs to be telescoping anyway, just make it so you can manually collapse it when on the field
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
Unread 12-01-2004, 15:06
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
Also keep in mind that you CAN power up your robot on the feild afterthe match. you could simply power up and reverse the mechanism or whatever is needed... if it is a pneumatic mechanism simply throw the release valve......
It's like those crazy physics teacher always said.... "What goes up, must come down."
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 12-01-2004, 15:29
Can you power up? Tethering on the field between matches has been greatly discouraged the last few years and I'd find it very surprising that tethering is allowed now. I suppose if thats all that can be done, then it would have to be allowed. But if someone has found something in the rules that says tethering is expected and accepted, I wouldn't rely on that as a solution.
There are many ways to solve this problem...but it is an issue that some teams will probably not take into consideration if they are not made aware of it.
Unread 12-01-2004, 15:47
Rule <T05>.
Unread 12-01-2004, 15:49
aKa - Steve Bennett
FRC #0125 (NUtrons)
WEll i remember that the hooks from the game two years ago were very passive systems that latched on and wouldn't let go... others were actually so sturdy that there was no way to remove them other than powering up... yes it is dicouraged but if u think about it, in the amount of time that it takes to lower the bar (if you seen it takes a while for that thing to come down), you definitly could be tethering up and retracting...
Team
....Uh, GO NUTRONS!
Unread 12-01-2004, 15:54
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
If I remember correctly, during the kick-off, Woodie said that the bar can be lowered if a team needs it. So if you have a simple hook that doesn't latch onto the bar, then the bar doesn't need to be lowered to get your bot off the bar and it won't be.
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 12-01-2004, 18:43
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
unless i'm mistaken, this is a circular bar, why not lift up the robot so as the bar comes down, so that when the bar is all the way down your arm is perpendicular to the floor
this probably doesn't make sense to anyone but me, but as i see it, there is no problem
Trust, Love, and Magic
Unread 12-01-2004, 18:50
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
because the robot has width, and would not be able to rotate, it would hit the floor
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 12-01-2004, 18:51
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
My only concern is that it is built to handle a beating. I hope the cable lifting mechanism is strong enough to hold 390+ pounds ( 3 robots)
The Bar is going to take many hits and abuse from robots
If the bar decides to come down there are going to be 2 or more unhappy teams with damaged robots...
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 12-01-2004, 19:23
Marygrace's Avatar
Marygrace Marygrace is offline
School=Build Season YAY
AKA: Mary
#0294 (Beach Cities Robotics)
Team Role: Student
Marygrace is just really niceMarygrace is just really niceMarygrace is just really niceMarygrace is just really niceMarygrace is just really nice
Send a message via AIM to Marygrace Send a message via Yahoo to Marygrace
I think FIRST would be able to use common sense, and know when to stop for robots to get off, and be able to decide whether or not they need to keep on going for others.
Unread 12-01-2004, 21:58
Well, as stated above T-05 seems to resolve all issues with this problem, so let this be a lesson to everyone - READ THE ENTIRE RULEBOOK BEFORE YOU POST SOMETHING AND LOOK FOOLISH LIKE ME
Kev
Raising the bar...or lowering it? Ben Mitchell General Forum 29 13-01-2004 03:30
Make the bar lower to get on? tkwetzel Rules/Strategy 28 12-01-2004 05:57
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
