Go to Post This tee-shirt collecting gets kind of addicting, doesn't it? - Chief Hedgehog [more]
Unread 01-12-2004, 11:26 AM
Andrew Dahl's Avatar
Andrew Dahl Andrew Dahl is offline
#0497 (Orange Crush)
Andrew Dahl is an unknown quantity at this point
hanging off off other robots that are hanging off the horiz bar
can it be done and is it legal
or how about allowing other robots to latch on to you??
thanks
dahl
2002 VCU Regional winner of the GM Industrial Design award
whooot!
Unread 01-12-2004, 11:38 AM
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Please Read The Rules !
PLEASE read the rules.
It is not stated as "illegal" but it won't score any points.
From 4.3.1 - Definitions (emphasis added)
HANGING – A ROBOT is considered HANGING from the Pull-Up Bar if it is directly SUPPORTED by the horizontal bar and is not touching the carpet, platforms, or goals.
and from 4.4.1 - Scoring
<G03> A ROBOT HANGING from the Pull-Up Bar at the end of a match is worth 50 points.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 01-12-2004, 11:40 AM
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: hanging off off other robots that are hanging off the horiz bar
thanks
dahl
It can be done, and is legal to do.
BUT, my interpretation is that both robots do not get 50 points, only the one attached to the bar gets the points.
SUPPORTED – If the “supporting object” is removed, the ball would not remain SCORED or CAPPED and/or the ROBOT would not remain HANGING.
Wetzel
Unread 01-12-2004, 11:55 AM
Stu Bloom's Avatar
Originally Posted by Wetzel
... my intrepretation is that both robots do not get 50 points.
I don't understand why you would say that ... I would think that the robot attached to the bar would still get the 50 points, as long as it is not "supported" (see your quoted definition) by the other bot.
Stuart Bloom
Mechanical Engineer
Unread 01-12-2004, 11:56 AM
Wetzel's Avatar
DC Robotics
Sorry, I'll clairify. Both do not get 50 points, only the one that is attached to the bar.
Read twice, post once!
Wetzel
Unread 01-12-2004, 02:18 PM
nic_radford nic_radford is offline
Engineer
#0118 (Robonauts)
nic_radford will become famous soon enough
If robot1 is hanging off robot2, then all of robot1's weight is still directly supported from the bar. The bar is holding all 260 lbs. We took that rule as to say that was allowed, and believe that it is.
"The world belongs to the energetic."
-Ralph Waldo Emerson
Unread 01-12-2004, 02:50 PM
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
FRC Video Review - Change is Coming
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Take the rules as they are stated, if it says you can get points by hanging off the horizontal bar, it means you can only get points by hanging off the horizontal bar.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 01-12-2004, 03:29 PM
Fiona Fiona is offline
FRC #0201 (FEDS)
Fiona has a spectacular aura aboutFiona has a spectacular aura about
Send a message via AIM to Fiona
The wording says "hanging from the horizontal bar". Is the other robot a horizontal bar? I don't think so....
Unread 01-12-2004, 04:26 PM
piotrm's Avatar
piotrm piotrm is offline
AKA: Piotr Mardziel
FRC #0190 (Gompei and the HERD)
piotrm has a spectacular aura aboutpiotrm has a spectacular aura about
Send a message via AIM to piotrm
I guess this is where differences of interpretation come in and FIRST probably needs to clarify. Most of the people that mentioned anything about this rule would interpret a robot hanging from another which is hanging from the bar as not scoring points. But I would definetly agree with nic_radford. At first reading of this rule it seems obvious (to me) that a robot hanging off a robot which is supported by the bar is also supported by the bar- a transitivity of sorts.
Unread 01-12-2004, 05:39 PM
I see one rule that applies to hanging, <G03>. Are there any others?
Here is my interpretation based on that rule.
<G03>
a ROBOT HANGING from the Pull-Up Bar at the end of the match is worth 50 points
since both ROBOT and HANGING are capitalized, they are defined. I won't waste my time with the definition of ROBOT, but the defenition of HANGING is as follows
a ROBOT is considered HANGING from the Pull-Up Bar if it is directly SUPPORTED by the horizontal bar and is not touching the carpet, platforms or goals
Now of course, that depends on the definition of SUPPORTED which is as follows.
If the "supporting" object is removed, the ball would not remain SCORED or CAPPED and/or the ROBOT would not remain HANGING
Now, by that defenition, a robot HANGING by another robot is SUPPORTED both by the first robot and also the bar. However, it is only directly SUPPORTED by that robot, and so does not meet the definition of HANGING and does not score 50 points.
However, I'm am open to the fact that there may be another place in the manual that casts some doubt, can you point me to it?
Unread 01-12-2004, 05:42 PM
animater31405's Avatar
animater31405 animater31405 is offline
AKA: ~Ka$h~
#0314 (Megatron Oracles)
Team Role: Animator
animater31405 is an unknown quantity at this point
Send a message via AIM to animater31405 Send a message via Yahoo to animater31405
And now I come in with the basic game rules. Any object attached to a robot is considered to be an extension of the robot. Applied to rule <G21>
~Ka$h~
Unread 01-12-2004, 05:50 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Not true
<G21> While a ROBOT is holding a LARGE Ball, that ball will be considered an extension of the ROBOT.
Also keep in mind that this situation will probably not happen, and when it does it probably will be a judges call, so its best to be avoided. Also you dont want to intentionally damage another robot by hanging on it, or you will be DQed.
Make the bar lower to get on? tkwetzel Rules/Strategy 28 01-12-2004 05:57 AM
What year was the hanging bar from? Jeremy General Forum 3 01-11-2004 11:00 PM
how effective do you think robots going under the bar archiver 2001 4 06-24-2002 12:36 AM
what do you think was... archiver 2000 15 06-23-2002 11:14 PM
How many robots on the bar in one match? archiver 2000 14 06-23-2002 10:39 PM
