Official Beacon Tracking Code Posted
I've posted the official IR beacon and IR beacon tracking and navigation code that was used at the kick-off here: http://kevin.org/frc. The folks at IFI will also be posting the code on their website. If you have questions about the code, please leave 'em here and I'll try to keep up
.-Kevin |
Re: Official Beacon Tracking Code Posted
Thanks Kevin,
Do we run this in the EduBot RC as a separate system? Is anyone able to convert this to Pbasic so I can run it on a Parallax BOE? |
-Kevin |
I haven't read up yet on this, but where can we find what materials we will need to actually emit the waveforms?
#7
Can you please describe the beacon waveform?
#8
-Kevin |
#9
Hmmm... I might have to look into the whole triangulation thing. Last edited by Rickertsen2 : 12-01-2004 at 23:21. |
#10
AArgh...
Can anyone help out a confused person?
First, should we use 180-degree servos or 360-degree ones? Second, minimum and maximum values for the servos are 0 and 254, respectively, right? Third, is left servo position-127=right servo position, the beacon is centered, right? |
#12
yes, we have successfully downloaded the frc default program. we have also tried to reset the controller, and when we do, the controller goes back into program state instead of running the program. has anyone else had this problem? i didnt change the navigation code before i downloaded it to the frc. thanks
becca |
#13
Kevin, Thanks for the link explaining that the system uses BOTH beacons instead of ONE. I guess it finally clicked. I had trouble understanding how to manuever both directions ( left and right )using using a single "line of sight" source. My trig skills havn't been used in 20 years so I hope the students can help us out with triangulation. I am still a little confused why 4 receiving LEDS are used and not 2, 1 for each beacon. ?? -Phil |
#14
-Kevin |
#15
-Kevin |
| What is your most prefered programming language? | Hailfire | Programming | 156 | 19-01-2005 21:42 |
| InfraRed autonomous code ... | mtrawls | Programming | 1 | 11-01-2004 00:25 |
| Autonomous code | PBoss | Programming | 7 | 14-01-2003 15:29 |
| Does your team use the Default code. | Jeff McCune | General Forum | 2 | 09-01-2003 14:46 |
| Patent source code? | Kyle Fenton | Chit-Chat | 3 | 20-10-2001 17:53 |
