Go to Post Tank tracks are one of those things that keep showing up on FIRST robots, in ways that I dont understand. - KenWittlief [more]
Unread 12-01-2004, 20:22
Jonathanb's Avatar
Jonathanb Jonathanb is offline
1037 S.C.R.E.A.M-a-holic
#1037 (S.C.R.E.A.M Team)
Team Role: Driver
Jonathanb is on a distinguished road
Send a message via AIM to Jonathanb
Exclamation Transmission HELP!!!
HI, Does anyone have a readable copy of Team 116 (Epsilon) 2003 dual motor, dual speed tranmission. I tried downloading them in the papers technical section,but half of the pictures don't appear.
Thanks,
Jonathan
Jonathan
S.C.R.E.A.M 1037
www.teamfordfirst.org/team1037
2004 Detroit Website Design Award Winner
Unread 12-01-2004, 20:29
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Transmission HELP!!!
Don't worry, it isnt just you. The file in the whitepapers section has something wrong with it. I don't know if I have a copy on this computer, but I can get a copy to you later tonight.
[edit] I have a readable copy. It is split into three parts that I can email you, if you get me your email address.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 15-01-2004, 02:58
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
try this link, its a pdf file of the most recent version.
http://www.team116.org/2003/document...criptionV6.pdf
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 16-01-2004, 23:04
Jonathanb's Avatar
Team Role: Driver
Thankyou both for all your help!!!
Jonathan
S.C.R.E.A.M 1037
Unread 21-01-2004, 14:18
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
There is an updated version of the Team 116 dual-motor, dual-speed gearbox design white paper that corrects the problem with some of the drawings not displaying properly with some versions of MS Word (I sent Justin a copy of this version earlier today). The submission section for the White Papers section is not yet working, so in the mean time you can download it from the Team 116 web site at http://www.team116.org/2004/Transmis...riptionV6a.zip. The file is about 1.1meg, and all the detail drawings have been broken out as .pdf files.
To anyone that is building this transmission, please note: there was a typo in the earlier version of the white paper. Part #10, "Torque Gear A" should be a 15-tooth gear (Small Parts part #B-GSS-2015). It is incorrectly listed as a 14-tooth gear. Please correct it if you have downloaded the old version of the white paper. It is corrected in this version (thanks to Stu Bloom/Team 1018 for spotting this!).
-dave
Unread 22-01-2004, 13:38
Jonathanb's Avatar
Team Role: Driver
Thankyou Mr. Lavery!
Jonathan
S.C.R.E.A.M 1037
Unread 23-01-2004, 00:53
dlavery's Avatar
Curmudgeon
Since a few people have asked, let me also add the following note:
For this design, Part #9 (Bosch Pitch Change Gear) is indeed a 55-tooth, 0.7 module gear. This is NOT a typo. They are available from PIC Designs, and can be ordered via their web site or phone-in orders. Just request part number MSG25-55 when ordering. In our experience, the delivery time for the 55-tooth gear is exactly the same as a more common 56-tooth gear.
The 55-tooth gear was selected as the best-fit solution for the matched free-speed design point we selected for this concept. There is legitimate debate about whether a 55-tooth gear is absolutely needed, or if a more commonly available 56-tooth gear is "good enough." If you like, you can drop in a 56-tooth gear instead. If you do, just adjust the center-to-center distance between the mounting location of the Bosch motor and the first torque shaft (Part 11) accordingly, and you should be good to go.
-dave
Unread 27-01-2004, 09:36
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
I ordered some 0.7 module gears over the summer from PIC, not the 55 tooth gear. The delivery time was at least three weeks. I would suggest for those people using 0.7 module gears to get their orders in now if they want to have the parts by the end of the build phase.
I may have had an odd part (48 tooth and 52 tooth). But, better safe than sorry.
Unread 07-02-2004, 02:36
Elgin Clock's Avatar
FRC #0237 (Black Magic)
We have decided to use this design this year, and fortunately the supplier you mention is right in our own backyard.. But we still had a very considerable lead time until one of our engineers talked to the guy on the shop floor at PIC and sweet talked his way into making them push our job ahead of some others because of our situation! Hehehehe!
Unread 07-02-2004, 18:29
dlavery's Avatar
Curmudgeon
OK, for all the teams that DON'T receive your gears from PIC until AFTER the ship date, now you know why!
Elgin - can you just have your engineer sweet-talk PIC into just running off 37 dozen of the gears all at once, and shipping them out to the teams that have ordered them?
-dave
Unread 07-02-2004, 21:16
Jonathanb's Avatar
Team Role: Driver
-dave
Whats interesting is that we ordered 4 of those gears from PIC on the 25 of January and we were told that we'd have them by the 22 of February. Now we couldn't wait that long so my Mom called PIC every day after the order and spoke to the productions supervisor, and he finally got tired of it so he said that we'd get them by the 5th of February and WE DID!!! GO MOM!!
Parents always seem to save the day,
Jonathan
Jonathan
S.C.R.E.A.M 1037
Unread 26-01-2004, 09:24
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Thumbs down I KNOW you are busy Dave, but PLEASE HELP again !!
... you can download it from the Team 116 web site at http://www.team116.org/2004/Transmis...riptionV6a.zip.
-dave
I have a couple of problems and need your help ...
First, the file I get using the url above will not open in my version of Winzip (v8.1). Actually the download is almost instantaneous - as if I may be getting only a header. And I get the message "Cannot open file: it does not appear to be a valid archive ..." when trying to open. I've tried downloading multiple times into different directories and under different filenames.
Second, I believe I have found another discrepancy with the prints (may or may not be corrected in the latest version... but I can't check because I cannot open the file). During our initial build attempt we had some difficulty assembling the side plates. After checking the .500 dia hole alignments I noted a significant mis-alignment of the hole pattern between the two plates, and a more detailed inspection of the drawings identified the problem. The offset .500 dia hole has a different vertical dimension by .076 (.734 vs .810). I believe the motor-mount side is the correct dimension (.734). I will contact you off-list to provide my email address and ask for the latest copy of your white paper.
Thanks!
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 27-01-2004, 03:03
dlavery's Avatar
Curmudgeon
Re: I KNOW you are busy Dave, but PLEASE HELP again !!
Thanks!
Let me see, how can I say this? Oh yeah, like this: "MicroSoft S*#@S!"
Now that I have that out of my system, I have given up on trying to get a MicroSloth-compatible version of the white paper that is generally accessible. I have re-posted a copy of the entire document as a compressed (.ZIP) .PDF file on the Team 116 server at http://www.team116.org/2004/Transmis...riptionV6a.zip
If for any reason that doesn't work, there is another .ZIPped version of the .PDF files at http://www.team116.org/2004/Transmis...iptionV6a2.zip compressed using a different tool.
These archives are ENTIRELY .PDF files, so hopefully no more MicroShaft document compatibility problems (keeping my fingers crossed!). The archive takes a little more space, but it should still work.
Regarding the hole alignments on the side plates, I really am not sure what you are refering to. I just went over the drawings of the side plates again to be sure, and the offset distances of all the holes are the same as far as I can tell. I see the 0.734" dimentsion, but am not seeing a 0.810" dimension anywhere on the print for either Part 1 or Part 2 (we are talking about those parts, yes?).
-dave
/edit I just went back and checked. There is a 0.810" dimension on a intermediate-development version of the design that we did last summer while updating the design to accomodate the new Bosch motors. Could you have somehow downloaded an obsolete version of the drawings? The URL above should point to the correct/current version - if you have any prior versions please throw them away and make sure you have the one referenced above. In the mean time, have I mentioned the problems I am having with MuckroSoft? edit/
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
Which teams are using a transmission this year Todd Derbyshire Scouting 10 08-04-2002 10:21
