I-sprocket?
Hi. Yesterday I was working on the inventor for our drive train, but we ran into a problem. One of the parts on the first cad library (i-sprocket.ipt) would not place right on the assembly. After I entered the parameters and tried to place it, Inventor gave me a long list of errors. Has anyone else had problems with this? Does anybody know how to fix it?
Thanks, Daniel |
Re: I-sprocket?
What Inventor are you using? It's been okay for me in 5.
Re: I-sprocket?
I am using inventor 6.
Re: I-sprocket?
I-factory parts will "blow-up" if you happen to choose parameters that don't make sense like a bore diameter thats larger than the OD of the sprocket. What parameters are you using ? |
Re: I-sprocket?
Paramaters:
Chain pitch: 3/8 in Number of teeth: 45ul Bore diameter: 5/8 in Hub diamater: 2.291 in Key Width: 1/8 in Hub: Compute Keyway: Compute Thanks, Daniel |
Re: I-sprocket?
It doesn't work for me in 7 either.
#7
I found the issue with I-Sprocket .......
It's posted in the First Cad Library. I've tested it under Inventor 5 & 6. If a few of you could please test this part with Inventor 7 and get back with me I would appreciate it. Big thanks to Daniel Wong for his assistance in tracking down the problem. PS. I've also posted the Grounding Terminal |
#8
Re: I-sprocket?
Thanks Ed. It's working for me now.
-Daniel |
| If set screws suck . . . | Madison | Technical Discussion | 17 | 22-12-2003 19:19 |
| wheel hub kit and sprocket | archiver | 2001 | 7 | 23-06-2002 23:27 |
| DP of Window Motor Gear? | archiver | 2001 | 9 | 23-06-2002 23:24 |
| control system programming | archiver | 2000 | 17 | 23-06-2002 22:14 |
| shaft drive | Joseph F | Technical Discussion | 5 | 03-02-2002 17:51 |
