Go to Post Since our team is in possession of the school, we have no restrictions on how late we can be there. So our teams are often practicing into the wee hours of the morning. Also, the school board uses "the breeze" for storage of high jump mats, so it's a great place to nap. :) - Karthik [more]
Unread 19-01-2004, 13:29
KBMSora's Avatar
KBMSora KBMSora is offline
#0486 (Positronic Panthers)
KBMSora is an unknown quantity at this point
IR Sensor Range Problems
We built the IR beacon and sensor, but when the sensors were hooked up to an oscilloscope the sensor only outputs when the beacon is less than a foot away. Is anyone else having this problem? If so, has anyone found a solution to this problem. Thanks.
Unread 19-01-2004, 13:48
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: IR Sensor Range Problems
Since you have a scope, check the signal that's getting to your IR LED on the beacon to make sure the beacon is assembled correctly.
The detector should be able to see the beacon at distances at least 20 or 30 feet away.
Also: the detector will only turn on for either 1ms or 2ms (depending on which beacon it's seeing) every 10ms. Did you zoom in enough on your scope to see that?
Unread 19-01-2004, 14:03
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Make sure the signal on pin 1 of Q1 of the beacon circuit looks kinda like one of the two waveforms shown in this illustration. Make sure that you swapped pin 2 and 3 of Q1 when you built the beacon. This schematic is how it should be wired. As Dave pointed out, you should be able to detect the beacon from at least twenty feet away. Let us know what you find out.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-01-2004, 14:10
KBMSora's Avatar
I'm told that the problem has been fixed. Thanks everyone for your help.
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Age of Mythology and its various problems mgreenley Chit-Chat 7 12-01-2003 14:20
EduRobotics problems Ian Mackenzie Robotics Education and Curriculum 22 14-12-2002 11:33
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
