Go to Post You pick the best person for the job whether they are black, white, asian, hispanic, female, or male; NOT so you 'look good' when they publish your team picture in the school paper, but because they can get the job done right, on time, with a passion. - Pavan Dave [more]
Unread 20-01-2004, 18:12
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Drill Motor pinion
We are TRYING to build team 116's transmission... and after much much hair pulling out I have found everything but the little oddball .7 module 55 tooth gear that is listed as msg25-55 (55 tooth). pic has no record of this gear, however they do have an msg25-56(56 tooth) listed. Was it a typo that 55 was used insted of 56. could an 7.5(edit ment 7.5) module gear be used to mate with the drill pinion? and does anybody know of a gear manufacturer that could supply one that can ship faster than 2 weeks (which i think is rediculous SP). basically im tired of fooling with this ordering stuff and I want to get to building this thing. I have look for the gear at mcmaster,grainger,msc, boston, martain, brown, sdp, small parts, berg, motion industries, everywhere... any help would be appreciated... *pulls out last of hair* (/rant)
(guess I should have also said that the plans call for an 55 tooth gear, whereas there is an 56 avaliable... i think were just going to order the 56 tooth, and if it comes in soon then we will use it.. if not.. well run drills alone and have it for next year)
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 20-01-2004, 22:56
kiracofe8 kiracofe8 is offline
#1317 (Digital Fusion)
kiracofe8 will become famous soon enough
Re: Drill Motor pinion
Originally Posted by Justin Stiltner
We are TRYING to build team 116's transmission... and after much much hair pulling out I have found everything but the little oddball .7 module 55 tooth gear that is listed as msg25-55. pic has no record of this gear, however they do have an msg25-56 listed. Was it a typo that 55 was used insted of 56. could an 7.5 module gear be used to mate with the drill pinion? and does anybody know of a gear manufacturer that could supply one that can ship faster than 2 weeks (which i think is rediculous SP). basically im tired of fooling with this ordering stuff and I want to get to building this thing. I have look for the gear at mcmaster,grainger,msc, boston, martain, brown, sdp, small parts, berg, motion industries, everywhere... any help would be appreciated... *pulls out last of hair* (/rant)
I was not aware that 7.5 was a standard module... I assume that you mean 0.75. In that case, the short answer is "no". A 0.7 module gear is only designed to mate with another 0.7 module gear and no other. The long answer is "maybe... but only if you know what you're doing". Technically, if you mount gears at a non-standard center distance, the "effective" module changes and this may allow you to use a 0.75 module gear. There is a lot of things to think about when doing this though, so I would only recommend it if you are a gear expert... since you're asking the question, I think it's a safe bet for me to recommend you not try this...
FWIW: a few years ago I was on a team that tried to build a custom transmission like this and we needed that oddball drill motor pinion. We couldn't find anyone to sell it to us, but we could find a machine shop with a wire EDM machine that was willing to make us one for free. That was pretty cool... You might see if you can find anyone in your area who could do the same...
/* Daniel */
Unread 21-01-2004, 02:43
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Justin -
For that design, a 55-tooth gear is correct. If you order the gear through the PIC Designs web site, just enter "msg25-55" instead of "msg25-56" (the "standard" part number that is on the list). The order will be accepted, and they will ship the 55-tooth gear.
-dave
Coupling the drill motor with out the 15 tooth gear Chopper_Dave Motors 1 17-01-2004 01:06
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
