Go to Post The honor from any given job is not so much what you are doing, but how you do it; the hardest working garbage man deserves more honor then the laziest super hero. - Josh Hambright [more]
Unread 20-01-2004, 21:44
cgav cgav is offline
cgav is an unknown quantity at this point
Sample Code (Line travel)
Does anyone have a sample algorithm for the autonomous mode (Line travel)? Thanks.
Unread 21-01-2004, 09:37
Re: Sample Code (Line travel)
This sample is from the EDU tutorial at: http://www.rec.ri.cmu.edu/education/...tent/index.htm
[code]
/* This program will track the left side of a dark line.
For this program to work, an IR Reflective Sensor must
be attached to Digital I/O Port 6, and must be placed at a
height where it reads 0 over a dark surface, and some other
number over a light surface. An analog optical sensor may also
be used, but the values in the program must be changed to
correspond to this light sensor's threshold between light
and dark values. */
void Default_Routine(void)/* BEGIN Default_Routine(); */
if(rc_dig_in06 == 0) /* if dark is seen */
pwm01=pwm03=127; /* turn left motors off */
pwm02=pwm04=96; /* turn right motors forward slowly */
else
pwm01=pwm03=159; /* turn left motors forward slowly */
pwm02=pwm04=127; /* turn right motors off */
printf("%d\n", rc_dig_in06); /* print light sensor readings */
} /* END Default_Routine(); */
[\code]
Autonomous Code From Experience EbonySeraphim Programming 7 14-03-2003 21:56
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
approach to autonomy Mike375 Programming 32 08-01-2003 14:04
