default code and the actual robot
ok did anyone have problem with the default code not working with the 'default wiring'? cuz ours seems to have a problem and we're trying to fix it
Re: default code and the actual robot
*bump...
hey BK
please do try to edit your messages before you post them. this applies to theory 6 forums as well ![]() |
im not good at grammar
what is wrong specifically? i know we had to reupload the default code like the default code reference guide suggested....mainly our prob was with the compressor and that fixed it...
my question was that when u just built the default code and loaded it onto the robot, does it work (robot's movement) properly for you guys?
#7
Thanx for the info but we are still having trouble with the code and our robot. I was wondering if u edited or changed the defauls code in any way before putting it on the bot? cause we were having a lot of trouble. another thing i was just wondering was r u guys using one joystick for ur bot or r u guys using 2???? and for my finial question i was wondering how u guys set up the motors for ur wheels( like in which pwm output pin u put them in?) all ur help is greatly appreciated. thanx
#9
What EXACTLY is the problem?
#10
if we load the default code onto the robot, the joystick is messed, x and y are switched, do u see that problem?
#11
I've seen it (left right on the joystick swapped)... but that should be easy to fix in the code...
| Help On Coding 2K1 Controller | GregTheGreat | Programming | 9 | 05-12-2003 18:35 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| New software?? | mjt902 | Programming | 2 | 08-01-2003 10:40 |
| PBASIC 2.5 answer from Parallax | JasonS | Programming | 6 | 07-01-2003 19:21 |
| Team 237 unleashes a "Beast" | Elgin Clock | Robot Showcase | 5 | 27-03-2002 21:09 |
