Go to Post I wouldn't want to face THAT bad boy in competition... - Iain McLeod [more]
Unread 25-01-2004, 22:57
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: cvt prototype
Unread 25-01-2004, 22:59
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Re: pic: cvt prototype
Why aren't you guys going to use this? It looks really cool and simple; why didn't it work in anything other than manual mode?
Did you have problems with the side-to-side slippage conflicting with the torque transferl?
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 26-01-2004, 18:12
Umm Errr...
Whoaaa.... Really cool idea, but probably impractiacal because of torque limitations. I must commend you none the less. There is a webpage somewhare that shows about 100 different CV designs. It's pretty cool.
1139 Alumni
Unread 28-01-2004, 12:38
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
the response time on the flywheel has to be a limiting factor, though - that much inertia would make quick changes difficult.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 28-01-2004, 15:02
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
The tigertrons came up with a similar design in the summer of 2002. We threw the idea out because we could not get any material to grip the aluminum disk similar to yours.
We even tried gum rubber. Thats were we got our gum rubber wheel ideas from...
We just mounted the aluminum disk right to the outside of 10 inch wheels. We moved the motors up and down on that disk. This also required way to much pressure on the motors against the wheel.
I also made an edu bot that had a variable speed that moved the powered wheels up and down on the drive wheel.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 29-01-2004, 01:10
REVving up for a new season
FRC #2848 (All-sparks)
i like the idea...that is just like the one in most snowblowers. the 1 comment i would sugest to you if you decided to use it in the future is to make the center of the flywheel flat (remove the nut/bolt) and inset it that way you can run your disk over the half way point and that way you could go backwards without switching direction of your motor.....just a sugestion...look for my to be posted in the off season unfortunatly machining problems kept me from finishing b4 season and i have no time now....but i swear i will get it done....nice job overall i am impressed
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 23-01-2004 12:11
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
