Go to Post That's one of the saddest stories I've ever heard. When your green isn't neon enough, you are in big trouble in FIRST. - JaneYoung [more]
Unread 27-01-2004, 23:37
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
Dashboard, The Comp and sensor data...
What are the rules on the dashboard program? I mean, we are allowed to use a dashboard durring the competition, right? What are the rules and regs in regards to what we can put on the dashboard? The way I understand it is we can display whatever we want as long as we dont have the computer directly controling the robot. Im asking because our team has never used a dashboard, since we have never realy needed to, and this year with the beacon/ tracker stuff a dashboard that would display a relative position on the field would be helpfull. We are having alot of success with the tracker and we can almost grid the position of the robot on the field. Also, what are the rules for sending specific data to the dashboard. Can we use unused PWM/analog inputs to send data to the controler/dashboard that would indicate, for example, the x/y position on our grid or somthing like error codes.
Thanks,
Kevin Karan
Programmer
Team 174
Arctic Warriors
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 28-01-2004, 11:46
Linux Guy
AKA: maxdamage
Re: Dashboard, The Comp and sensor data...
eh, Does no-one know, or does cant anybody understand my question?
Unread 28-01-2004, 11:48
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Your dashboard program can display anything you want it to based off of the data coming out of the dashboard port. Last year our team had a Palm-based dashboard that plotted the location of our robot on the field in real-time during autonomous, for instance.
You are correct also that the laptop can only be used to receive information from the OI. It cannot be used to control the robot.
Unread 28-01-2004, 12:39
Linux Guy
AKA: maxdamage
Alright, thanks
Unread 28-01-2004, 21:02
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
CAN the dashboard port be used to control the bot? or do you have to use something else?
Unread 28-01-2004, 21:03
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
This was JUST aswered.
it CAN NOT control the robot, but can do what ever you please with the info you stream to it.
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 28-01-2004, 21:11
AKA: Jamie Bliss
I ment, is there implications for it? (Nothing about rules)
Unread 28-01-2004, 21:31
Linux Guy
AKA: maxdamage
no, if you wanted to, you could mod a serial or paralell port to send data to one of the joystick ports
