Go to Post No matter what the weight limit is, a large number of teams will *ALWAYS* have trouble making it. - Cory [more]
Unread 29-01-2004, 17:54
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
Timing Codes
Does anyone know where to find the timing codes for the PIC?
Unread 29-01-2004, 17:56
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Timing Codes
How so? you can have one of the timer interupts increment a variable, or count iterations throught the main loop.
Unread 29-01-2004, 18:02
Re: Timing Codes
Well I'm not looking to see how fast an algorithm would run. I'm looking to see how many cycles different instructions would take. Like an opcode reference.
Unread 29-01-2004, 18:22
AKA: Jamie Bliss
Re: Timing Codes
I'm not sure I understand entirely, but by the sound of it, I'd suggest using a timer interupt.
Unread 29-01-2004, 18:47
Umm Errr...
Re: Timing Codes
Well there are 2 ways to do this.
1.) View the disassmebly code output from the compiler and trace the program flow.
2.)Set up a timer that rums in the background and times different operations.
Btw.. although the processor is 40mhz, one operation takes 4 clock cycles. Hence 10mips.
1139 Alumni
Unread 29-01-2004, 20:53
SeanCassidy's Avatar
SeanCassidy SeanCassidy is offline
Antiregistered User
#0263 (Aftershock)
SeanCassidy is an unknown quantity at this point
Re: Timing Codes
This helped me a lot, it allows you two write two different but very acurate timers.
http://www.innovationfirst.com/FIRST...004-Jan-14.pdf
Unread 29-01-2004, 21:02
Re: Timing Codes
Not quite what I was looking for. There are some x86 opcode references that have an estimate for the number of cycles it takes to execute an instruction (This would be dependant on the maker of your cpu). I was wondering if anyone has seen something like this for the PIC18F8520?
Unread 29-01-2004, 21:04
Umm Errr...
Re: Timing Codes
they all take 4 cycles except i think retfie(i think i'ts retfie. you better double check this). See the datasheet.
1139 Alumni
Unread 29-01-2004, 21:33
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Timing Codes
It's not for the same model of PIC, but here is one document that lists the cycle times for various instructions - many of them may be the same (there's other stuff in the file too, scroll down):
http://www.microchip.com/download/li...och/40170b.pdf
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 29-01-2004, 21:43
Umm Errr...
Re: Timing Codes
the cycles listed there should be the same. the 18x series has some additional instructions though. What they call 1 cycle refers to 1 instruction cycle not one clock cycle.
1139 Alumni
Unread 29-01-2004, 21:44
Re: Timing Codes
Thank you deltacoder, this was exactly what I was looking for (or pretty close). Finally tommorow I'll be off academic probation and back doing my passion =D
Unread 29-01-2004, 22:26
Computer Guy
AKA: Dav
Re: Timing Codes
amazing what Google can find good luck on your programming - we just finished our drive base today, so now I get to start having some fun. (My team leader would probably shudder if he heard me saying that.)
Alt codes in Forums? Elgin Clock CD Forum Support 2 27-09-2003 00:45
Swapping codes miketwalker Programming 8 22-02-2003 15:26
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
two sided timing belt archiver 2001 3 23-06-2002 22:34
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
