Go to Post They can either incorporate the suggestions in this thread, go totally against them, or even make us all write code on banana peels with our fingernails. - Andy Baker [more]
Unread 30-01-2004, 06:55
Ogro Ogro is offline
Ogro is an unknown quantity at this point
Question Gears
I trying to find the INVENTOR gear library, but unfortunately I couldn't. I realized that I don't even know if it exists. I remember that the MECHANICAL DESKTOP has it... Can anyone help me with that??
Unread 30-01-2004, 07:02
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
Re: Gears
I am not sure whether there is such a library for Inventor, but Ed Sparks does have an iGear on the FIRST cad library. The file, http://www.firstcadlibrary.com/drawi...r(English).zip, lets you choose bore, hub, tooth, pressure angle, DP. It isnt a true involute gear but it is a very good approximation. Hope this helps.
-Rc
Unread 30-01-2004, 09:44
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Gears
You could try www.cbliss/inventor/ for all types of iParts from gears to bearings to hardware.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 30-01-2004, 14:35
Henry Anthony Henry Anthony is offline
FRC #1250 (GATORBOTS)
Henry Anthony is on a distinguished road
Re: Gears
You could try the Boston Gear website. They have 3d models of most of their parts in multiple formats.
Best regards,
Henry
Unread 30-01-2004, 16:29
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Gears
When you received Inventor, it should have 3 discs. Disc 3 contains the "Inventor Modules" which, when installed, should allow you to access the parts library. I dont remember gears in it, although I could be wrong. Your best bet is to use Cbliss or www.FIRSTCADLibrary.com
Cory
2001-2004: Team 100
2006-Present: Team 254
What type of steel are gears commonly made from? Matt Adams Technical Discussion 5 02-01-2004 23:19
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
replacement gears joni_m Technical Discussion 1 22-01-2002 18:01
