Go to Post Read it, Loved it, posted it on facebook! - wendymom [more]
Unread 31-01-2004, 14:44
Mark Reynolds's Avatar
Mark Reynolds Mark Reynolds is offline
#0329 (R.A.I.D.)
Team Role: Driver
Mark Reynolds is an unknown quantity at this point
Send a message via AIM to Mark Reynolds
Question Varification Required
Can someone please varify the following code function?
In the file: users_routines.c
Under the section: "Buttons to Relays"
relay8_fwd = !rc_dig_in18; /* Power pump only if pressure switch is off. */
Please varify that we are indeed setting relay8 to Pin18 which is set as an output? We are confussed because this is the first year we have seen this. Thank you
Unread 31-01-2004, 17:01
Umm Errr...
Re: Varification Required
It sets relay 8 to the opposite of pin 18 which is set as an[b]INPUT[/]. Hence the "!" operator. This means that when the pressure is to high( switch is closed circuit) the compressor is shut off. When the pressure is too low( switch is open circuit) thne compressor turns on.
1139 Alumni
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
Robot Numbers - Required Mike Martus OCCRA 0 25-10-2003 16:18
Would you like 'Preview' to be required in order to post? Brandon Martus CD Forum Support 18 09-03-2003 18:12
Team 308 Pictures (and a little story, too) archiver 1999 12 23-06-2002 22:52
Additional Parts Required for the Control System?? Tom Fairchild Electrical 4 17-02-2002 15:01
