Go to Post ...and then at the end they interviewed this 5 year old on his favorite part (of the fair): "I liked the robot" - Jessica Boucher [more]
Unread 31-01-2004, 19:20
bob1million's Avatar
bob1million bob1million is offline
#0825 (Swivvey-gus Maximus)
bob1million is an unknown quantity at this point
Desensitizing Joysticks
My fellow programmers and I have tried many different ways to desensitize our joysticks, but none of ways work very well. Does anyone know a good way to desensitize them?
"Death smiles at us all, all a robot can do is smile back."
Unread 31-01-2004, 19:47
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
Re: Desensitizing Joysticks
Why dont you just get new joysticks. very good ones can be found for cheep
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 31-01-2004, 20:14
WillyC's Avatar
WillyC WillyC is offline
"handy"
#1347
WillyC is on a distinguished road
You could make a different "transfer function" for the joystick in the form of a lookup table. For instance, right now the transfer function for joystick input to motor output is purely linear (not including the x and y axis mixing). It's linear in the sense that the motor output is linearly proportional to the joystick deflection from neutral.
You could make a slightly non-linear lookup table to de-sensitize the joystick in whatever region of deflection you want. This is actually what I use this lookup table generator for - to rapidly prototype and test new transfer functions for the joystick.
If you want some help, let me know...
Unread 31-01-2004, 20:35
how much do you want to back them down?
lots of teams just divide the joystick variable by 2, then add 64 to make 127= center again
or divide it by 4 and add 96 to make 127 = center
you can have this as optional code, with a button or operator switch that lets you switch between normal and "fine tuning" mode of driving.
Unread 31-01-2004, 20:47
Gusman1188 Gusman1188 is offline
FRC #0870
Rookie Year: 1930
Gusman1188 will become famous soon enoughGusman1188 will become famous soon enough
We played around with joysticks for a while trying to desensitize and the only way that we found effective is to just state something like the following
if (p1_y <= 135 && p1_y >= 127)
p1_y = 127;
if (p1_y >= 119 && p1_y <127)
p1_y = 127;
We tried this but just decided to buy new ones or use last years.
Team R.I.C.E. 870
2006 SBPLI Regional Winner
2006 SBPLI Imagery Award
2005 SBPLI Regional Winner
2004 SBPLI Xerox Creativity
2003 SBPLI Regional Winner
2003 CT J&J Sportsmanship
2003 SBPLI KPC&B Entrepenuership
2002 SBPLI Rookie All-Star
Unread 31-01-2004, 21:11
Vladimir Vladimir is offline
the Impaler
#1064 (Wild Beast)
Vladimir is an unknown quantity at this point
Send a message via ICQ to Vladimir Send a message via AIM to Vladimir Send a message via Yahoo to Vladimir
Here's how I'd do it... first psuedocode for understanding:
x1 = p1_x; // get an axis, store it in temp variable
x1 = x1-127; // make 0 = neutral
x2 = abs(x1); // find magnitude from center
x3 = (x2/127) * x1; // create harshly curved value
x4 = (x3+x1)/2; // average curve with real to lessen curve
p1_x = x4+127; // restore neutral to 127 and replace value
then this should actually work and is a lot more concise... it assumes you have an abs( function available, either include a math library or make your own with something like if (x<0) x*=-1; -- I haven't tested this so don't run me over with your robot if it doesn't work off the first try, there may be some casting or something required with this compiler, but it'll at least be close.
p1_x-=127;
p1_x = ((p1_x*abs(p1_x)/127)+p1_x)/2+127;
Hope this helps some!
-Sean
B.R.E.W. (Better Robots Engineered Wisely)
Unread 31-01-2004, 22:20
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Hmmm... I'm not a programmer, but I think a large hammer would do it!
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 01-02-2004, 00:47
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
p1_y = 127;
p1_y = 127;
All this could be rewritten as one line:
if ((p1_y <= 135 && p1_y >= 127) || (p1_y >= 119 && p1_y <= 127)) p1_y = 127;
Unread 01-02-2004, 02:55
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
and heck, if readability is your issue, just include the 127 case as well:
if(p1_y >= 119 && p1_y <= 135) p1_y = 127;
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 01-02-2004, 10:40
KevinB's Avatar
AKA: Alum
Looking back at my statement reminds me of why coding at midnight is bad.
Unread 01-02-2004, 10:55
I dont understand how putting a deadband around 127 will make the joystick less sensitive
in fact, your bot is going to lurch when the joystick is moved just outside the deadband
dividing the joystick variable by two, and then correcting the zero point by adding 64 - makes the full forward or full right... positions of the joystick equal to half forward, or half right... making the entire motion of the joystick less sensitive
and making it easier to make fine control adjustments to the motion of the machine while driving - ie when you want to manuver to capture a ball, or position the robot precisely on the field.
Unread 01-02-2004, 12:59
WillyC's Avatar
"handy"
#1347
I've got to agree with Ken on this one. This deadband approach will make the joysticks more sensitive, because the motor output is proportional to the joystick deflection. If you ignore the stick input unless it's greater than 135 or less than 119, then as the stick moves out of the deadband and starts the motor moving, the motor's smallest non-zero speed is even faster than without the deadband. The result will be jerkiness as the bot starts moving.
Ken's solution sounds good, and is obviously more efficient than what I'm about to suggest here. I haven't tried my idea on the bot yet, and I'm a little sketchy about putting a lookup table of any size into the user routine because I don't want to slow it down too much. But here's the principle: make a slightly non-linear lookup table to de-emphasize the stick input near neutral, but not near the max/min. I've attached an example of the kind of curve I'm thinking of. Notice that near 127, it "dumbs down" the stick input to drive the motors slower and make the sticks less sensitive, but near the high or low end of the input it looks almost linear to make the driveability at high speeds feel pretty normal.
Try it out and let me know what you think! Like I said, I haven't tried this on the bot yet...
EDIT: I just changed the .xls to a zipped up .xls.
Unread 01-02-2004, 13:21
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
That is very helpful file.
What i was thinking is, have a max change function in real-time like you mentioned.
Basically you jus need a variable that holds the current joystick input. For example if your joystick was at 135 and you pushed it to 250 all of a sudden, You can check you current motor output which was 135 and then current joystick input which is 250, now you keep adding a certain number lets say 10 to the motor output untill it reaches 250.
This is one way to do it, the other way is to subtract 250-135, you get 115 devide it by a number lets say 10 so you get 11.5 , now ur max change is 11.5 , add that 10 times to your motor output or until it reaches desired position, this way you will have variable max change function.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 03-02-2004, 09:20
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
You could use low pass filter. I'm at school right now and don't have access to what I've written, but I'll try to post it when I get home.
Unread 03-02-2004, 09:47
WillyC's Avatar
"handy"
#1347
This is what I love about programming...there are so many different ways to solve the same problem. All of these are nest ideas. Good luck everyone!
Programming joysticks NoRemorse Programming 29 24-02-2004 20:26
number of joysticks doy Rules/Strategy 5 01-02-2004 00:05
Team 524 has Team 362's spare joysticks from last year. archiver 2001 0 24-06-2002 02:36
Could use some help with joysticks . . . archiver 2001 5 23-06-2002 23:36
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
