Go to Post And remember, it's the fall semester. So FIRST isn't an excuse for a failing grade (not that it's ever an excuse)! - Billfred [more]
Unread 05-02-2004, 21:36
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
radiosity and rendering
I have a question.
If i use radiosity w/ photometric lighting to render one of my scenes and animate a character, will it calculate radiosity for each frame since the character will be moving? I know that it doesnt recalculate the radiosity solution if you move the camera around, but what happens when you move objects? I haven't had the time to test render the animation since we haven't finished our character rigging.
-kevin
team 75
www.roboraiders.com
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 05-02-2004, 21:49
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Re: radiosity and rendering
This is straight form the 3ds max 5 manual, and it holds true for six:
Object Animation
The radiosity solution is calculated for each frame if any object is animated in the scene (the default is to calculate the current frame only). You specify the parameters (goals/quality) you want to reach in the Advanced Lighting dialog. It is recommended to run a solution first and verify if it’s successful before proceeding to the whole animation. These parameters will then be reprocessed for each frame.
You go to the render dialog, Common Parameters rollout, and enable the option Compute Advanced Lighting When Required, and then render the scene. The radiosity is processed for the first frame and then rendered. 3ds max then moves to the next frame, processes radiosity, renders, and so on.
Hope this is sufficient.
Last edited by Bduggan04 : 05-02-2004 at 21:50. Reason: spelnig, cross that... spelling
Unread 05-02-2004, 21:53
Matt Hallock Matt Hallock is offline
#1188 (Oaktown Crewz)
Matt Hallock is on a distinguished road
Send a message via ICQ to Matt Hallock Send a message via AIM to Matt Hallock Send a message via Yahoo to Matt Hallock
Yes, it will recalculate every time because the light is being re-emitted off of the moving object each frame.
Lead Animator for Donder-Kimball High School, team #1188.
Unread 05-02-2004, 22:09
kcy88's Avatar
Animator
AKA: Kevin
hmm.. thanks alot.
Unread 06-02-2004, 22:26
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
a quick note about radiosity, i would tend not to use it for videos, becuase it takes way too long and it will not improve the quality THAT much. radiosity is good for stills, where detail is not lost due to either the quick animation (it stays still so you can take it all in) and/or compression. in my opinion, unless you have an extremely fast computer (not pc, im talking like a supercomputer) or a renderfarm, using radiosity would be very impractical
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 06-02-2004, 23:32
I run on a Athlon XP 1800+ (Overclocked to 2 Ghz) and the radiosity calculation time, even for very complex rooms, takes maybe 30 seconds to a minute. However, he's correct, if you're computer is slow, say below 1400, I'd not even bother with it.
Unread 07-02-2004, 16:58
av11d's Avatar
av11d av11d is offline
College Bum
no team ((Team 75 Alum -- Capt 05 & 06))
av11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to behold
We're using top of the line P4 laptops with high end mobile video cards. Radiosity does take a bit, but our longest shot contains no animated objects, only a moving camera, so radiosity shouldn't be too much of a problem.
Unread 07-02-2004, 17:49
If it's P4 it isn't top of the line, I've used both in their supposed equivilants, AMD is usually 25-35% faster in calculating and rendering.
Unread 07-02-2004, 21:54
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
Not in 3dsmax. newer P4s outperform Athlon XPs by a lot, and are still faster than new Athlon64s by 5-10% (in most cases)
Unread 07-02-2004, 22:20
kcy88's Avatar
Animator
AKA: Kevin
Our current radiosity settings:
Initial Solution: 50%
Iterations (all objects) 1
Raytrace GLobal settings:
max depth: 3
I've been able to decrease the render time to 5-6 mins when it calculates radiosity. THe scene has about 205 objects. I'm satisfied with the current results, but if anyone has suggestions please speak out.
I don't think render time will be too much of a problem since we aren't using it for the entire animation. We're only planning on using radiosity in the first 10-15 secs, then switching over to light tracer.
How is everyone else's animation coming along?
-kevin
team 75
www.roboraiders.com
Unread 08-02-2004, 02:39
Eric Rowe
ok, if youre using radiosity at that quality (50%), it shouldnt be a problem, but the time increases expodentially so it want, say, a 90% solution or higher, it can take quite a long time. good luck with everyones animation.
Eric Rowe | Alumn
Unread 08-02-2004, 11:45
http://www.anandtech.com/cpu/showdoc.html?i=1946&p=6
If I find the CGtalk article I will, a guy was using a P4 against his Athlon XP. The XP came out on top. That link there shows that the A64 is faster, albeit slightly, than the 3.2 GHZ P4EE.
Unread 15-02-2004, 00:19
kcy88's Avatar
Animator
AKA: Kevin
ugh...
its whenever i render, it keeps recalculating radiosity! why?
omg.
i'm pretty sure no objects are moving, except the camera.
Unread 15-02-2004, 00:59
It's looking at it from a different angle each time, all renderers (Atleast ones that use some form of indirect illumination and sub-surface scattering) recalculate what they do each time.
Adding realism through plugins or alternate rendering engines anishthakkar 3D Animation and Competition 3 10-01-2004 17:26
Radiosity simulations Daishichimaru 3D Animation and Competition 2 02-02-2003 19:42
