Go to Post A drag racer can have all the output torque in the world, but it does no good on ice. - Paul Copioli [more]
Unread 06-02-2004, 12:26
rocko rocko is offline
rocko has a little shameless behaviour in the past
Lightbulb HELP!!! Referring to power at comp!
does anyone know whether or not we can have our own batteries and/or power outlets at the competition to run the operator interface? please reply
asap....
team 1317
Unread 06-02-2004, 12:33
EIROBOTICS86's Avatar
EIROBOTICS86 EIROBOTICS86 is offline
#0311 (Red Jammers)
EIROBOTICS86 can only hope to improve
Send a message via AIM to EIROBOTICS86
Re: HELP!!! Referring to power at comp!
asap....
team 1317
what do you mean exactly?
Unread 06-02-2004, 12:40
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
The power for the operator interface comes from the competition port. There will be NO ac power outlets available at the operator stations.
Tim Tedrow
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 06-02-2004, 13:34
Lightbulb Re: HELP!!! Referring to power at comp!
i mean can you have backup batteries to give power to the control panel that the drivers will be using, to power vf displays and such? i already figured out that you can't have ac plugins, but im not sure if we can supply our own power. if not, what gauge wire can i have from the competition port?
rocko
Unread 06-02-2004, 13:42
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
rocko
You will have no direct wires coming out of the comp port in the drivers station. There will be a cable that will plug into your OI while in the match in the drivers station. While not in a match for testing, you must use a tether from the OI to the RC to power your bot. And to answer your question on if you can use extra power to run displays in the drivers booth, that is not legal to do.
-Michael Dessingue
Unread 06-02-2004, 13:58
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
It is legal to have palm pilots and laptops connected to the dashboard port and they have batteries. This question should be posted to FIRST with a little more detail about thing you're going to use.
- Gene Falendysz
Unread 06-02-2004, 22:41
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Everyone is assuming that you are talking about at the drivers station? Is this what you mean or do you mean power in the pits?
If this is the case, you do have power in the pits for obvious reasons, but you MUST tether your robot in the pits to do testing.
Unread 07-02-2004, 00:13
Umm Errr...
MY interpretation of the rules would be that you
CAN:
use extra batteries
power off the LED, outputs (although they probably can't source enough for a VFD)
CAN'T:
Draw power directly off the competion port
1139 Alumni
Unread 06-02-2004, 13:57
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
I haven't scoured this year's rules, but in the past I believe the rule was that you could use batteries for powering things like LEDs or laptops/Palms connected to the dashboard. However, don't even think about trying to power the actual OI with your own battery. The OI gets its power through the competition port. When you go up to the driver's station for a match, there's a cable there that you have to plug into your competition port (meaning you can't have anything of your own plugged into it). That cable configures your OI for the correct channel, and automatically controls the enabling/disabling/autonomous activation of your robot.
Also I assume by "vf display" that you mean vacuum-flourescent? You may want to rethink the idea of using that type of device with your robot, since it generates a lot of RF noise and could potentially interfere with your robot communications. If you do decide to use it, try to locate your radio modem as far away from the display as possible, and keep in mind that if you experience any radio modem problems that the first thing Innovation First will probably tell you to do is to get rid of the display.
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
power to the pits Ken Leung Off-Season Events 12 11-05-2003 22:48
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
