pic: Team 30 Dual-Motor Transmission
Re: pic: Team 30 Dual-Motor Transmission
<sarcasm>I don't think it's beefy enough. It looks rather fragile, almost as it it might spontaneously fall apart at any second.</sarcasm>
Really though, good job. Looks great! The only problems as far as i can see are: 1.)a bit heavy |
Wowie.
Hey, one question.. where did you get the .7 mod gears to match with the drill? And.. how fast did you get them? Thanks |
Let me guess, they each weigh approximately 7-8 lbs each?
We didn't use the .7mod gears, the gear on the drill is a 20 DP that we put on it. As for the weight im not sure how heavy it is, but it is sturdy to say the least. Not too expensive to make either, ~$100 per side.
-Rc |
A few Questions:
What is the 20P gear on the drill, how did you put it on, how did you get the old one off, and where did the new one come from? Thanks. EDIT: I see some potential problems, you have a shaft collar riding right up against the Oillight bushing, and it looks like you may have gears with the same problem. Also, I assume you are supporting the end of that output shaft, if you weren't planning on it, please do. Last edited by sanddrag : 07-02-2004 at 00:11. |
#7
Sanddrag: you can get the new gear from pretty much anywhere. I ordered oen from Motion Industries yesterday. Im guessing they press fitted it onto the shaft of the drill motor. As to how they got it off, search. I remember Paul Copioli posting a neat little machined piece that you made, then screwed an M5 screw through, eventually popping the pinion off the shaft.
Cory |
#8
What speed did you calculate that to drive your robot at with the 12.5 inch wheels your using? I looked and took some educated guessed and calculated it to be about 15.8ft/s. Did you run any numbers on that to obtain your current draw at that speed? How about how well the robot will turn with 4 pneumatic wheels? Also from the drawings it doesn't appear like the bosch is held into the gearbox with anything, is it connected at the bottom in an unseen way? I also share the concern about that output shaft, I would not recommend to have something that long as a cantilever shaft. It also looks like you are planning to have the gearbox slide into the chassis and be bolted in. I have had experiance with mounting gearboxes like that and I would suggest against it, espescially with a more than 2 wheel drive robot. Under the highest stress situations, the gearbox will be sliding around on you and the bolts will try to loosen.
#9
You can take the gear off the drill motor with a good old fashioned dremel. Just don't let shavings get in the motor. It's good fun, really.
#10
How many of those are you using?
#12
Ok, lets think about this for a second. How many times have you tried to dremel the pinion off the drill motor and failed personally. 0. In fact, how many times have you actually tried to dremel the pinion off of a drill motor? 0. So, you have no right to say it shouldn't be done. If you do it carefully and cover the motor, you will have no problems. It's really very simple. You are basing your opinion off of zero evidence. So please stop talking. |
#13
I'm not sure what speed the wheels will be turning, becuase we can adjust what sizze sprockets we have the chains going to. If we want more speed we can lower the ratio. As for turning we were concerned that it might have the "jumping" problem but we ran it and had no issues, turned just fine. We never cantilever drive shafts, there is a pillowblock that the output shaft goes into already on the frames. I'm not sure how they bolted it on however becuase I'm at college ~100+ miles away.
The gear that is on the drill we ordered through motion industries, it is made by boston gear. It was press fit on. The drill motor is held in place by the giant shaft collar that was machined for it, it was run for about 20min at full speed with no slipping. -Rc |
#14
The calculation I did was with a 12:60 sprocket reduction and thats the biggest possible with ordering from mcmaster and such. What are those gear reductions in there? From observation it appears you might have the numbers wrong with your bosch motor, but knowing the actual teeth numbers would be nice.
#15
Caution to all reading this thread. Some of the processes expressed by some of the teams are very risky. Please use well thought out processes based upon "best practice" and above all practice safety at all levels.
Also consider advice from the persons that have expertise in the field of question as more reliable but not faliable. All are entitled to their opinion on how to best do something but again excercise caution. |
| The Death of FIRST | Anton Abaya | General Forum | 23 | 03-05-2006 17:18 |
| The 2003 Index of team's post about their robot... | Ken Leung | Robot Showcase | 4 | 28-02-2003 00:18 |
| More 'Best' Robots (a well thought list) | archiver | 2000 | 2 | 23-06-2002 23:11 |
| Disqualifications | archiver | 1999 | 13 | 23-06-2002 21:53 |
