Go to Post I am a geek. - Andy Baker [more]
Unread 09-02-2004, 13:44
ESchneider's Avatar
ESchneider ESchneider is offline
Eric "Schroder" Schneider
#1018 (Pike Robodevils)
Team Role: Student
ESchneider is an unknown quantity at this point
Banner Sensors
Is anybody having trouble with the Banner sensors for this year? I was able to set it up all nice and stuff, but it only seems to detect objects and distance. Last years were able to see white and black. Any suggestions?
Unread 09-02-2004, 13:50
Re: Banner Sensors
they are designed to work with retro-reflective tape, but last years units were able to discriminate between the white tape and the carpet.
the ones we got this year are infared instead of visable red. I dont know if that changes the colors it will discriminate between.
Unread 09-02-2004, 14:59
Re: Banner Sensors
Did you try adjusting the sensitivity using the black control on the back?
Unread 11-02-2004, 09:33
ESchneider's Avatar
Team Role: Student
Re: Banner Sensors
I tried adjusting the sensitivity on them. Nothing much happened there. I did not know that we were using reflective tape. That will help alot. Thanks!
Get Your philosophy from a bumper sticker-Billie Joe Armstrong(Green Day)
Team #1018 Pike Robodevils www.robodevils.com
Unread 11-02-2004, 10:42
Re: Banner Sensors
' it only seems to detect objects and distance."
I have no clue what you mean by this. The Banner Sensors emit a beam of pulsed light, and look for that beam to be reflected back
if it sees the reflection, it turns on
the beam is focused somewhat like a laser pointer - last year you could see the dot so you had a better idea of what it was hitting
it will reflect off retroreflective tape up to 20 feet away, and off other surfaces that are much closer.
so I dont understand what you mean when you say it will detect objects
and distances?!
maybe if you could explain what you want to use them for we can give you better answers.
Unread 11-02-2004, 10:54
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Re: Banner Sensors
Last year we did some testing and actually had them reflecting from over 30+ feet with retro-reflective tape.
However, other surfaces, like the palm of my hand, we had about an inch or two.
Any somewhat reflective surface should work decently though, I think.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 11-02-2004, 11:25
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Banner Sensors
Not true, as this year's Banner sensors are not the retroreflective model. This year the kit provided the "diffuse" model sensor instead, which is designed to sense a nearby object (100 to 400mm according to the specs). I haven't tried it, but according to the literature, these sensors shouldn't be able to detect retroreflective tape (unless it's really close, that is).
Check out this link at Banner Engineering for a description of the two different modes. Click on "Choosing a Sensor: Sensing Modes" and then choose either "Diffuse" or "Retroreflective" on the left hand side.
Unread 18-02-2004, 12:02
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: Banner Sensors
I thought that this years banner sensors are also retro reflective tape, as it turns out they are diffuse, can anyone tell me what type of surfaces or colors they can detect.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 18-02-2004, 12:17
Re: Banner Sensors
Pretty much anything that reflects the detector light, including the carpet if your sensitivity is adjusted too high, and retroreflective tape. The effect of the diffuse light is to restricted detection range.
From the site Dave referenced here are detectabilities of some common materials:
http://info.bannersalesforce.com/xpe...1_s1_e.pdf.pdf
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
Banner sensors cadets Electrical 3 04-12-2003 14:30
banner sensors edomus General Forum 7 20-11-2003 19:43
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Model No of the Banner sensors ? Lloyd Burns Technical Discussion 3 16-01-2002 14:51
