pic: Team 710 Drive module
Re: pic: Team 710 Drive module
Here's one of our drive modules for this year its got two wheels and both are connected by chain...that's all i'll say for now oh and one on each corner of our robot
Is it 4 wheel drive or 8 wheel? What I'm asking is will the lawnmower tires and the skyways be touching the ground at once or will the assembly pivot so you could have only the lawnmower or skyways? I imagine you chose the lawnmower wheels to have more grip for climbing.
Or maybe you're planning on mowing the lawn with your robot after competition? A robotic lawnmower! |
Right now its 6wheel drive, 2 of the assemblies only have one wheel in them, and yes the assembly pivots
![]() edit: originally we planned for 8 wheels but took out a 7th and 8th wheel due to weight (our biggest enemy this year) |
My guess would be that those modules themselves actually rotate. Put down the slick wheels for turning, the beefy ones for pushing, and rotating them climbs the step too. We considered something similar to this, but decided against it for weight reasons.
you could mill a TON of weight out of that aluminum plate, maybe on all 4 you could remove a lot of it and be able to put all 8 original wheels back in. just a suggestion
#7
Ya we thought about takin out some pieces. Those two-wheel module weigh about 6.7 lbs and the other ones weigh only 6, only problem is we don't have much time to take and mill out some weight and the structural integrity of those is really important
#8
I don't disagree we could use some weight. But when it comes down to it.. its not really a ton It was barely noticeable Last edited by Dan Richardson : 04-03-2004 at 00:47. |
#9
Think about bridges, for example. Trusses support immense load, yet they're largely open space. Cutting a similar pattern of triangles into plates such as yours is often an effective way of reducing weight while maintaining strength. |
#10
it's amazing how simalar those are to ours.....
#11
EDIT: Picture link above fixed now. Last edited by sanddrag : 04-03-2004 at 01:20. |
#12
From what i have seen you guys 73, us 710, and 258 have a similar design with the "gurney" style drive.
#13
fixed
#14
Well except for the fact that have a considerable amount of spacers running through the centers where these designs would be cut out. And we did run into problem withs spherical our cuts weakening the system. Infact the forks we milled where the only ones we had problems with
I was not saying that it couldn't be done. I was saying that the difference in the weight made is basically nothing. its 3/16th alluminum and we could cut out a max of about 1x2 inches. Weighing only a few grams. ( to be exact its about 0.0360 lbs per piece ) If it had been better designed in the beggining when those parts were designed it could have been designed with the cut outs inplace. But with our current system it can not be done with enough effectiveness to cause reason to do it. But again, the extra work done on it, and the weight gained we felt were too minute to deal with under our certain time restraints. THanks for the advice tho keep it coming Dan ps. see our bot in action ( sorry for bad editing job, I'll be re-editing this weekend hopefully ) View Us Our forks in action Us hanging because of our lifting system Last edited by Dan Richardson : 04-03-2004 at 00:49. |
#15
Heres a lower resolution vid (5MB as compared to 25MB)
Low Res 710 Video ps .avi's soon to come if this one doesn't work (people have told me that it won't work on their computer.) |
| pic: Team 60 Drive Train Parts | CD47-Bot | Robot Showcase | 17 | 07-02-2004 01:58 |
| The 2003 Index of team's post about their robot... | Ken Leung | Robot Showcase | 4 | 28-02-2003 00:18 |
| pic: Team 870 Rear Drive Train | CD47-Bot | Robot Showcase | 2 | 27-02-2003 00:22 |
| pic: Team 980 "Thunder Bot" drive train | CD47-Bot | Robot Showcase | 12 | 25-02-2003 14:02 |
