Every time I try to transfer a hex file to the robot, It says "Unknown Device id (0)"
What does that mean? |
Re: IFI Loader:Unknown Device id (0)
I've seen that sometimes when the wrong COM port is selected in IFI_Loader.
Are you using the serial port on your computer or something like a USB-to-serial adaptor? Try this: Under "Port Settings" on the IFI_Loader window select each of the available COM ports one at a time and try Downloading over each one. |
I'm using a USB-Serial cable. Although I've got 10 com ports, I know its in COM 3. I'm trying to find the driver for the USB-Serial in case i need to install it again.
Ignore what they declare it is and test each port anyway. |
Thanks again. It works, of course.
| IFI Loader usually hangs midway thru load | gnormhurst | Programming | 4 | 04-02-2004 11:40 |
| IFI Loader Problems | BrendaB | Programming | 3 | 24-01-2004 22:45 |
| IFI Loader Doc's | Raven_Writer | Programming | 0 | 21-01-2004 17:53 |
| Bug in IFI Loader | rwaliany | Programming | 2 | 06-01-2004 21:26 |
| IFI Controllers For 2004 | Ian W. | Rumor Mill | 22 | 01-10-2003 16:09 |
