Conditional #define Statements
I'm rewriting the navigate.c class for our team, and I've come to an annoying problem.
I have two sensors, left and right, for each side of the robot. Depending on a switch, only one should be read. That means I can save on code, I think. With PBASIC, a simple if statement and alias command would set "sensor" to "left_sensor" or "right_sensor" but I have no idea how to do this in C, without going into pointers (which I don't remember). Is there any way I can make a conditional #define (or similar) statement? |
Re: Conditional #define Statements
Why not just have a conditional declaration?
if(your condition is meet) { int your_var; } else { int something else; } I'm probably misunderstanding you but its still worth a shot. |
1) You know at compile time which one you want Code:
#if IWANTVAR1 #define myVar var1 #else #define myVar var2 #endif //myVar now refers to var1 or var2, depending on IWANTVAR1 (which MUST be either a constant or expand to a constant) Code:
int myVar; if(iWantVar1) myVar = var1; else myVar = var2; I hope this is what you wanted... |
Ah, thanks, I didn't think about doing something simple like just reassigning the variable to a temporary variable. Seeing as I only need to read, I think I can make do with that, but I'll have to fool around with it a bit.
On the other hand, it's always a good time to relearn pointers... |
| Contradictory FIRST Statements | Gobiner | Rules/Strategy | 10 | 14-01-2003 16:12 |
| Calling all Lawyers... ...Define "all parts" | Joe Johnson | General Forum | 10 | 13-03-2002 15:12 |
| Logical statements or math formulas | Manoel | Programming | 1 | 16-02-2002 23:29 |
