Go to Post Sure, it's just a robotics competition, but some of us actually care about the robots... - Karthik [more]
Unread 15-02-2004, 13:52
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Two Compressors
I have a question. Is it legal to use more than one compressor on the robot? I searched on CD and couldn't find an answer. Also when following the parts use flow chart I'm getting confused. If you consider the compressor a pnuematic item it seems to be allowed, but if you consider it a motor it isn't. We have several extra compressors since we aren't a rookie team. Does anyone have an answer. If there is an answer or an actual post I missed can someone please point it out to me.
The problem is we are using three large cylinders and the compressor and air tanks can't keep up. We even added extra lengths of tubing to increase storage. The two compressors will be wired separately with separate fuses but plumbed together. The max psi won't change but we will get increased volume to run the cylinders. This will also take the burden off of one compressor, and we also realize it will drain the battery quicker.
If anyone else has any other ideas I'm open to suggestions.
Thanks,
Jason
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 15-02-2004, 15:20
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
Re: Two Compressors
you may not use two compressors i know its in the rules somewhere i just dont have time to find it
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 15-02-2004, 15:25
occra 23.
AKA: ryo
None #1481
Re: Two Compressors
im also pretty sure you can't use two cylinders.
also, there was a forum on using extra tubing as a 'kinda' air tank. it turned out that that wasn't allowed. but if you reaaally need more storagetanks, you could use extra cylinders (not tanks) as a tank. i think.
Unread 15-02-2004, 15:56
Re: Two Compressors
actaully it doesnt matter how much storage you have, if your compressor cant keep up with your air demand
I take it you are using the pneumatics to move an arm or something, and when you move it back and forth a lot the tanks run dry?
in that case you want the hose between the compressor and the tanks as short as possible, so it have the least amount of resistance (more airflow) and you want to regulate the pressure to the cylinders as low as possible for the task you are performing, to use the least amount of air - also you might consider using a cylinder with a smaller diameter, that wont use as much air as a large one (if you dont need all that force)
BTW - putting extra cylinders in your system WONT give you more capacity because they are past the regulators, you would have to put them on the high pressure side of the regulator to store air - and that is against the rules.
Putting extra cylinders in your system will keep your pressure from dropping as low as it would without them, but it wont let you cycle your clinders any faster, because the only air coming into the system is through the compressor. If you 'need' 60 psi then you cant get it by using extra cylinders as storage.
Unread 15-02-2004, 16:05
occra 23.
AKA: ryo
None #1481
Re: Two Compressors
KenWittlief, you're right. i was actually considering using more cylinders as tanks. good thing i posted a mistake thanks!
Unread 15-02-2004, 16:12
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
Re: Two Compressors
That is not entirly true. Although the cylenders would only store 60 PSI, they would have increased volume on the system. More volume means that the pressure that exists when the active cylender is extended will be more. More volume will always help.
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 15-02-2004, 16:22
Re: Two Compressors
no - if you need 60 psi on your active cylinders, then the extra cylinders will only be holding 60 psi - so they cant source any air that wont have to be replaced by the compressor - so it will take LONGER for your regulated side to get back up to 60 psi
cause the compressor will have to fill the cylinder that you moved and the unused ones that are just sitting there. Without the extra cylinders the pressure would have dropped lower in a smaller volume of space, and the compressor would fill the space faster (due to the lower backpressure). With the extra cylinders in there, the pressure wont drop as low, so the compressor has to pump the same amount of air back in, but at a higher back pressure.
To use extra cylinders as storage you would have to use two regulators - putting the extra ones at 60psi, and using the active ones at something less, probabally 30psi for the extra ones to do any good.
and that will still only help you if you dont use the pnuematics for a while, then you use them alot for a minute, then you dont use them for a while again.
Unread 15-02-2004, 16:29
Re: Two Compressors
now that I think of it, you are better off using a larger diameter cylinder at a lower working pressure than you are using a small diameter at a high pressure
because the compressor can pump more volume of air at the lower pressure - so that approach would let you cycle the cylinders more frequently.
if you are running larger cylinders at 30 PSI then the tanks can drop to 32 psi or so before your applied force starts to drop - and the compressor can get more volume at 30 than at 60
if you are running them at 60, then the compressor will start to fall behind at 62 psi,and will have a harder time keeping up with the demand.
Unread 15-02-2004, 16:30
Just Browsing
AKA: ryan albright
Re: Two Compressors
i thought you are only aloud to use two storage tanks and then as many cylnders as you want
doesnt it say somewhere you can use only whay you are supplied wiht
ex
given two motors = only aloud two motors
2 storage tank = aloud only two storage tank
etc
Mentor 1083 2005
Unread 15-02-2004, 17:46
AKA: Jason Hartmann
Re: Two Compressors
I just want to thank everyone for their answers. Today was the first time we really got to test our robot with all the systems on it (currently 134#) pulling itself up to the bar. We noticed the compressor had to run almost continuously to keep up. We are aware it is slightly overweight since no weight reduction has been done yet. We didn't want to remove any "realestate" yet in case we have to change anything or remount anything in an area we milled out. We also shortened the tubing to normal lengths to neaten up the robot and very minor weight reduction. We also played around with psi and found out 40#'s is the lowest we can go. The reason I posted this is we were considering adding two compressors to increase volume which in turn would decrease system recharge time if we could get the weight down enough.
Unread 15-02-2004, 18:58
Aidan F. Browne's Avatar Unsung FIRST Hero
Aidan F. Browne Aidan F. Browne is offline
Engineer
AKA: The Aidan-bot
Aidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond repute
Post Re: Two Compressors
If you read rules <R01> <R54> and <R70> it is clear that only one compressor (pump) may be used on a robot.
Aidan
Unread 15-02-2004, 20:05
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Two Compressors
For the purposes of your question, I believe that the compressor would be considered under the electronics/motor-pump thread of the parts use flowchart. Per the flowchart, multiple compressors would not be allowed (ie the second compressor did not come in the kit, and it would be an additional motor/solenoid/pump/actuator, and then lead to the "No, it cannot be used" answer. Since you are on a veteran team, you also know that in the past FIRST has made it pretty clear that you cannot use multiple pumps.
You should post the question to FIRST for the official answer, but I am fairly sure that it will not be allowed.
-dave
Unread 15-02-2004, 20:17
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
Re: Two Compressors
-dave
I agree with Dave that using a second kit pump would not be allowed.
However, FIRST has said that an off-the-shelf vacuum pump could be used as long as it's powered by a kit motor. Could an off-the-shelf compressor be used if it's powered by a kit motor?
That sounds like a good question to post on the Q&A.
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
