Where do the victor motor 3 pin wires plug into exactly? The victor motor is hooked up to the van door motor.
-Vex |
Re: Please help asap
One side of the cable plugs into the PWM input on the Victor, and the other goes to the PWM Outputs on the RC. Make sure that you plug into both correctly. The victor has the letters W,B,R to represent the color of the wire. The RC also clearly labels which colors go where.
When it comes to connecting the PWM cable, it doesn't matter which type of motor is connected. You will choose which RC output based on your software. As a side note, the Spikes would plug into the Relay outputs of the RC. |
Re: Please help asap.. Where do the victor motor 3 pin wires plug into
They connect to the pins that say "PWM Outputs"
They are at the top of this picture http://www.innovationfirst.com/FIRST...Controller.gif |
I'll contact you via PM
#7
I hate to sound mean, but you should really read the IFI docs. Everything you're asking about is explained VERY clearly in the information provided by IFI - you'll be better prepared to work with the control system if you have a fair amount of familiarity with it, and spending 20 minutes flipping through the manual is a good way to gain that familiarity.
#8
merci anyway |
#9
Plug the one end into the Victor with the black wire closest to the fan.
Plug the other end into a set of 3pins on the Robot controller that is labeled PWM Outputs. The number of the PWM (1-16) is the number you need to use in the code to control that particular speed controller. ie. We have a Victor for the left drive that is conected to PWM16 The right Drive motor connected to PWM15. In Our code we say Code:
pwm15 = 254; pwm16 = 0; // reversed due to motors pointing opposite. If we plugged the motors into pwm1 and pwm2, and used the above code, the robot would not be sending the signals to the right jacks. Hope this helps. Remember frustration will just frustrate you farther and nothing will get accomplished. Reading the documentation is always a good idea and will assist in clarifying what you are trying to do. ![]() Phil |
#10
| Ir Sensor Needed Asap! | Ryan Albright | Electrical | 10 | 14-02-2004 13:06 |
| Very BIG bug...Brandon, please fix this one ASAP! | IMDWalrus | CD Forum Support | 1 | 11-02-2004 22:42 |
| Q&A Discuss: FESTO Help ASAP!!!! | CD47-Bot | Extra Discussion | 3 | 16-02-2003 10:55 |
| Course Curriculum for A First Class, Please Respond ASAP | archiver | 2001 | 0 | 24-06-2002 01:33 |
| survey for the guys..but i need results ASAP | A. Leese | Chit-Chat | 4 | 05-06-2002 16:50 |
