Go to Post I wish my biology class was this exciting. - MissInformation [more]
Unread 16-02-2004, 20:33
Lou Lou is offline
Lou is an unknown quantity at this point
Question inputting data for autonomous mode
so i want to put this code i got from the website
http://www.rec.ri.cmu.edu/education/...tent/index.htm
specifically the IR Reflective Sensor Program for line tracking
now in which file would i put thise code into?
although the instructiosn say to put this code into user_routines.c,
i thought you put autonomous code programming in user_routines_fast.c?
can anyone shed some light?
thanks in advance
-noob at programming
this is the code for line tracking
void Default_Routine(void)/* BEGIN Default_Routine(); */
	if(rc_dig_in06 == 0)  /* if dark is seen */
		pwm01=pwm03=127; /* turn left motors off */
		pwm02=pwm04=96; /* turn right motors forward slowly */
	else
		pwm01=pwm03=159; /* turn left motors forward slowly */
		pwm02=pwm04=127; /* turn right motors off */
printf("%d\n", rc_dig_in06); /* print light sensor readings */
} /* END Default_Routine(); */
Unread 16-02-2004, 21:33
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: inputting data for autonomous mode
take the code from inside the Default_Routine() function, and put it in the User_Autonomous_Code() function (in user_routines_fast.c) instead. it should look like this:
/* in user_routines_fast.c */
void User_Autonomous_Code(void)
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
        else
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 16-02-2004, 22:26
Lou Lou is offline
        else
thanks alot for your help!
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Competition Scouting pauluffel Scouting 31 09-01-2003 00:34
Robot Scouting Database archiver 2001 10 24-06-2002 03:00
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
