Lots of Electrical Questions
We are a future 2005 rookie team. We tried this year but couldn't get the registration fee, but we're building a robot anyway to practice. Electrical is one of our weakest points. Here are our questions, well a few of them.
1) We have an Edu RC, will have either a 2002 FIRST RD or a 2003 one, and are trying to find at least close to an official battery. What other electrical stuff do we need? 2) I am pretty sure we at least need a fuse box. Where does that go and how do we connect it to where it needs to go? And where can we find one and how much does it cost? 3) Where are we supposed to connect the motors to? And what about pnuematics. Where does the compressor hook up to (provided we can find one to use) and where do the solenoids (we have two of those) hook up to? 4) An engineer on my other team (226, I'm a mentor/alumni), one of the engineers someone said something about being able to connect the two RC's (The Edu and the FIRST one) so that our programmer can still use C (What he's been learning) but we can use the operator interface from the FIRST one. Can anybody explain this furthur? Everything we have so far (6 motors, 2 pistons, 12 bearings, surge tank, 2 solenoids, 8 sprockets, chain, other cool stuff) was donated by 226. Thanks TEC CReW! Allison Last edited by Allison K : 17-02-2004 at 12:47. |
Re: Lots of Electrical Questions
Its not clear what parts and controller you have?
the EDU bot from last year only runs Pbasic, not C (and by last year, I mean the 2003 competition year - the EDU robot controllers for this year were actually shipped out in the fall of 2003, but they are considered to be 2004 units) Have you found the documentation at www.innovationfirst.com ? the documents for the older EDU bots is all there in the 'previous' archive section. if you have the full size robot controller from a previous year, then you will want to take a look at the archived manual from that year at www.usfirst.org - they have all the wiring diagrams in the robot section of the manual - bwteeen those two websites you should be able to find all the instructions and drawings and schematics you need to expeiment with what you have. Good luck towards next year - hope to see you at a regional. and please feel welcome to continue this discussion with any questions you have - I dont mean to dismiss your questions by pointing you towards websites - most of what you need to know is already there. |
We had enough money to pay our down payment for the EDU, so we have the 2004 EDU kit, but an old full size RC, or will have an old full size RC.
I guess a better question would have been, After the battery and the controller, what is the bare minimum of other electrical stuff. We're running on a 300 budget, hence the reason most of the other stuff was donated. Hmmm. It was rather depressing when we first found out that we couldn't officialy compete, but I've come to realize a practice year is definiely a good thing. I'm almost glad we weren't stuck trying to figure all of this out in six weeks. Allison |
If you're using any of the full-sized motors, you will need some Victor 884 Speed Controller modules (883s will probably do for now) and/or some SPIKE Relay Modules.
We have two 3/8" drill motors, two Van Door motors from ?2001? I think, and two other motors that I'm not sure what they are. They are about 2 in long and have a square shaft covered in plastic that lies perpendicular to the motor. I'll take a picture at meeting tonight and post it.
Then you will need some speed controllers for the drill motors and the van door motors, and spikes for the window motor.
#7
Okay. What do speed controllers and spikes look like, how do I explain to the team what they do, where can I get some, and how much do they cost.
Allison PS- Sorry about asking so many questions but I really know nothing about electrical, and as I am the team leader I am expected to know something. |
#8
I think they retail for $120 or so each, but I'm sure some teams will have extra 883s which can no longer be used in competition, but are fine for everything but the latest drill and chiaphua motors. The Victor is a square base with a LED on it, and a mini tower coming up with a fan mounted at the top. The SPIKE is a little box which has either a red or blue SPIKE label on the top. Both are labeled very prominently, so if you see one you'll know it.
#9
OK thanks. And when we put these on the robot, We wire the motors to the victors/spikes and the victors/spikes to the RC?
#10
A nice electrical diagram put out by FIRST can really help you out a lot:
http://www2.usfirst.org/2004comp/200...rev0120704.pdf |
#11
Thanks DJ.
So to make sure I have this all right. The two 3/8" drill motors each go to a victor 883. The victors connet to the circcuit breaker (same this as a fuse box?). The two van door motors are the same as the drills- motors to victors to circuit breaker. The two window motors each go to a spike which connects to the circuit breaker. For the pnuematics, both the solenoid and the compressor connect to spikes. -Are the spikes really necessary? -Why do the solenoids we have have four wires each? Do they all connect to one spike, or do we need two spikes for each solenoid? More questions. -Do we need more than one circuit breaker? -How do we connect the Circuit Breaker to the RC? -Can the 2004 EDU RC handle all that, or do we need to connect that stuff to the old full size RC? Allison |
#12
Best of luck to you getting a team together for 2005! |
| 3 Questions!!! (2/5/04) | Andy Grady | General Forum | 11 | 05-02-2004 21:14 |
| 3 Questions!!! (1/5/04) | Andy Grady | General Forum | 8 | 05-01-2004 16:01 |
| A Few Electrical Questions | GregTheGreat | Technical Discussion | 16 | 30-10-2003 20:42 |
| $3500 limit - Who does not have questions | Raul | Rules/Strategy | 5 | 12-01-2003 11:31 |
| pre-inspection preparation questions | Adams High Man | OCCRA | 7 | 22-10-2002 22:22 |
