Go to Post [how to read the rules] Slowly, carefully, word by word, taking your time as if it was the last corndog of the summer. - Foster [more]
Unread 17-02-2004, 13:21
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Using ground stem for power distribution
I'm currently using the ground stem as a power distribution - I have a bunch of connectors bolted on. It is properly insulated, very small chance of anything going wrong. It does not touch the robot frame, etc. Is this legal? I am using it in place of the power distribution brick, as it is smaller, lighter, and can use the right size wiring. I see no problems, but I wanted to check. Also, people keep saying that you must adhere to the power distribution chart. The way I read the rules is that this is a suggestion, not absolute law. What's the ruling on this?
Thanks,
Steven
Unread 17-02-2004, 13:42
Re: Using ground stem for power distribution
You MUST use the ground stud as a gatherer for all the incoming grounds. In the set up you have now, this is not possible.
Unread 17-02-2004, 14:27
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Apparently not, from the Q&A today:
Q: According to the "robot power distribution diagram", all ground wires go thru the ground stud. R44 allows connecting directly to the fuse panels. Can we loop from panel to panel (as shown for the red+) or is the ground stud required?
A: Either way is acceptable.
Unread 17-02-2004, 14:28
hmmm, i wasnt aware of that update.. thanks for keeping an eye out!
Unread 22-02-2004, 20:01
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
okay but is the ground stud required on the robot or can we use a replacement equivilent (ground bus) our team never got a ground stud and there fore it was never mounted.. you see where this is going
"You're not a real programmer until all your sentences end with semicolons;"
Unread 22-02-2004, 20:05
I would not use the ground stud as a +12V stud - its too open and could be easily shorted to the chassis by a stray piece of metal, or a loose screw.
Unread 22-02-2004, 20:11
AKA: theshadow
FRC #0620 (WarBots)
i wouldent try to use it as a +12v stud (lol thats what the main breakers for) but i was just wondering if we needed it at all. the q/a above is kinda blury, i read it as not all of the grounds have to go thrugh the stud. but do any of them have to?
Unread 22-02-2004, 21:43
no you dont need to use it, and if you do there should only be 3 wires on it - one coming from the battery
one to the buss box that takes #6 wire on one side and #10 on the other
and one to the ground stud on the small breaker box.
Its much easier to put the #10 wires on the buss box, and on the ground pushon terminals of the smaller breaker box than to have an octapus on the ground stud.
Unread 22-02-2004, 23:12
If it's too open and easy to short, even when covered with electrical tape, shouldn't we remove all of the rest of the electrical components too? I don't see how it's different...
Unread 23-02-2004, 11:40
zeep25's Avatar
zeep25 zeep25 is offline
AKA: Adil Karim
#0369 (Team Nuts and Volts)
Team Role: Webmaster
zeep25 is an unknown quantity at this point
Send a message via AIM to zeep25 Send a message via Yahoo to zeep25
well we cant find out ground stud so we used a simple bolt and use a lock nut and a regular nut to use it instead of the ground stud
Roles: Programmer, Webmaster, (All rounder) including Electrical and Mechanical
Gearbox - Team Nuts and Volts - 369
http://www.gearbox36.org/
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
Ground Stud Teedoff101 Electrical 11 16-02-2004 07:20
Choosing a Linux distribution Robby Chit-Chat 8 03-01-2004 23:02
Weight Distribution Mechanism in Tread System? Kai Zhao Technical Discussion 8 20-08-2002 16:38
