Go to Post When a team is a team, anything is possible - Bharat Nain [more]
Unread 18-02-2004, 21:52
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Legality of Spring Loaded Pistons
Based on the part flowchart, spring loaded pistons are ok... is this true? Can someone post a specific reference in the rules stating their legality?
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 18-02-2004, 22:17
Re: Legality of Spring Loaded Pistons
do you mean spring loaded pistons that you buy from somewhere? or adding springs to the pistons from the FIRST supplier list?
are you talking about pneumatics?
Unread 18-02-2004, 22:23
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Aren't all of the above legal? (Except a pneumatic piston not from FIRST's supplier)
Team 1257
Unread 18-02-2004, 22:36
yes, they should all be legal - you can add springs to retract the pneumatic cylinders if you want
and you should be able to purchase an off the shelf spring loaded piston device, as long at its not a pneumatic cylinder from 'someone else'
Unread 18-02-2004, 22:41
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Does bimba sell pre-spring loaded pistons? Because that would be very awesome. Not that I could use it but I would solve a couple teams problems.
Unread 18-02-2004, 22:42
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
I agree with Ken, following the flow chart, there seems to be nothing wrong with using a Spring Loaded Piston, as long as it does not violate the ruling for custom pneumatic parts.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 18-02-2004, 22:52
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
i have about 10 bimba pneumatic cylinders that are 3/4 " stroke 1 1/2" bore. and they are spring loaded in a way. They don't have a second air intake thing but instead just a small hole. We bought them at princess auto for about $2 each. We didn't use them this year just in case they weren't allowed to be used on the robot
Unread 18-02-2004, 23:07
AKA: Nelson Green
Yeah do the make those things in 24" stroke and 2" bores. Because that would help several teams. Like 134.
Unread 19-02-2004, 01:08
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Spring-loaded pistons are NOT legal. Review the fourth paragraph of <R54> and the parts-use flowchart (including the expanded flowchart in Rules Update #10) VERY carefully.
Is a spring-loaded piston an air cylinder ordered from the Custom Cylinder Order Form? No.
Is it a purchased cylinder or actuator IDENTICAL to those available on the Custom Cylinder Order Form? No.
Spring loaded pistons are not available on the order form in the pneumatics manual. Therefore, you cannot purchase pistons that are spring loaded.
-dave
Unread 19-02-2004, 01:19
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
I stand corrected, I did not see the updated Flow Chart in this team update, I apoligize.
Unread 19-02-2004, 01:22
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
if i am right arent we allowed to use springs this year?, than why not attach the spring seperately to that part your piston is going to be on, and the whole thing will act as a spring loaded piston
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 19-02-2004, 01:30
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
I'm pretty sure this would be legal, seeing as how you're not modifying the piston itself in anyway.
Unread 19-02-2004, 01:38
AKA: Nelson Green
Yeah, it would be legal but a manufactured one would be better in this case because it is designed to work in this way but a team designed one might be more dangerous. A pre-built one would be easier to implement into the system too. Too bad, the rule is clear now. Just make sure your spring loaded device doesn't break the 10 ft/sec rule.
Unread 19-02-2004, 17:20
sorry for the confusion - I did not mean piston = pneumatic cylinder - I was thinking of a spring loaded piston as a spring device, not something that uses air pressure to move.
Bosch Drill Motor Clutch Spring Dimensions?? aaronbr28040 Motors 3 18-02-2004 19:52
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
