code violation...need help
We are having a problem surrounding the downloading of the hex file onto our robot controller. We tried to even download the default code and it doesn't work when we plug in the radio transmitter (get error message with radio modem). Can you help us?
Re: code violation...need help
what gives you an error message?
you cant use the radio modem to download your code, if thats what you are trying to do - you need to use the serial cable |
we downloaded the program with a serial cable, but when we plug in the radio we get a code violation
Try hitting reset...Its might work. I'm not too great with the programming but we have to reset ours after every time we run it.
Is the radio modem in the right port? On both ends.
| What is your most prefered programming language? | Hailfire | Programming | 156 | 19-01-2005 21:42 |
| Interrupt timer, executing code asap? | SeanCassidy | Programming | 10 | 07-03-2004 01:47 |
| Inserting Naviagation code into Default code? | actorindp | Programming | 3 | 28-01-2004 18:12 |
| Does your team use the Default code. | Jeff McCune | General Forum | 2 | 09-01-2003 14:46 |
| Patent source code? | Kyle Fenton | Chit-Chat | 3 | 20-10-2001 17:53 |
