Go to Post ...many different kinds of students join our team. Some only have an interest in media, or others in cheering. What is important is that they are having fun while working in an engineering environment. - Bharat Nain [more]
Unread 21-02-2004, 14:32
Jesse Jesse is offline
Jesse is on a distinguished road
A few last minute questions
1. is the distance to the edge of the immobile goal 24 feet? i have heard a few different answers n i want to clear it up
2. how do i hook up and use the pressure switch? is it digital or analog, n which wires do i use?
Unread 21-02-2004, 19:31
Re: A few last minute questions
the mobile goal is in the center of the field, and the dimesions of the field are in the manual - Im pretty sure its 48 feet long
there are two pressure switches - one is digital On/Off and has two screws for wires, and one is analog and has three wires - check the robot section of the manual for the proper way to connect them - the digital one goes to the digital inputs on the RC - you will have to sacrifice a pwm cable to connect it to the digital inputs, or buy the right connector and use the small gauge (grey) two wire cable that came in the kit of parts (KOP)
there is an input and a relay output already configured in the default code to run the relay (compressor) until the digital sensor detects high pressure, then turn the compressor off until the pressure drops below its lower trip point.
the default code is described in detail in the users guide in the documents section of innovationfirst.com.
I know everyone is in crunch mode right now - when you get a chance go through those documents - if you are working on the RC you will really want to know them inside out when you get to the regionals and something is not exactly right with your machine :c)
3 Questions!!! (2/20/04) Andy Grady General Forum 20 20-02-2004 17:31
Current Monitoring system questions PyroPhin Technical Discussion 44 17-02-2003 15:34
$3500 limit - Who does not have questions Raul Rules/Strategy 5 12-01-2003 11:31
Update 7 - Behind Schedule (or out of questions)? archiver 2000 2 23-06-2002 22:58
2-3 minute Interview at Pit Table ben_whly Chairman's Award 5 01-04-2002 16:00
