our beacon sensor can't find the actual beacon tower at a far distance. it only finds it at very very close distance, like 1 cm away. we even put tubes around it so the direction of the waves is in one direction instead of all over the place.
does any one know of any solution to making the becon sensor work properly? thanx Last edited by anupalsingh : 22-02-2004 at 23:44. |
Re: Beacon Sensor Problems
Did you see the update about the incorrect value of the resistor included with the beacon kit. I dont remember what to replace it with though, you will have to check on that. Also, try moving it into an open space where there isnt much for the ir to reflect off of.
Do you have the beacon wired properly? The schematic that came with it is incorrect. Extremely short distance is one of the effects of the miswiring (others include excessive power draw, and overheating of components in the circuit). Check the correct schematic located here: http://kevin.org/frc/
You also might want to look at the FAQ at the same location. Hope this helps... |
We ran into this problem too. Much past 20 feet or so the tracker was horribly inaccurate. It'd find the beacon OK, but it'd be +- 10 degrees, which doesn't help things terribly much.
I completely re-wrote the tracker and receiver code and interrupt routines in order to get a 3 sensor tracker. I added a third sensor in the middle that simply stares down a bic pen tube and is completely sealed off with electical tape. Works incredibly well this way, as the tracker needs to be pointing *directly* at the beacon in order to get all three receivers to register. I can post pictures / code if you want. |
yea, if u can, please post the pictures and code
and thanx a lot random dude, it probably was wired wrong, i'll give it a check. Last edited by anupalsingh : 23-02-2004 at 17:43. |
The way we have them coded, the trackers never stop moving. When they find it, they keep scanning untill they loose it, then they go back till they loose it the other way. We save thoes values and average them. Then we can "safely" say we know where they are. Also, the way we have them set up, they are very accurate at long range. Its nothing like firsts example, instead of the eyes like fish eyes, they are both faceing forward and are separated in the middle, this helps with accuracy.
#8
| Official Beacon Tracking Code Posted | Kevin Watson | Programming | 41 | 18-02-2004 21:04 |
| IR Beacon/reciever not working... still... | Ferazel2001 | Programming | 23 | 04-02-2004 23:30 |
| ir beacon range | doy | Programming | 10 | 29-01-2004 16:46 |
| edu and ir beacon | alan koch | Robotics Education and Curriculum | 4 | 26-01-2004 22:43 |
| Making a beacon indicator LED burn its brightest without burning out | DanL | Electrical | 7 | 26-01-2004 08:05 |
