Go to Post Disclaimer: I am not an electrical engineer nor an electrician. I occasionally play one on CD. And when inspecting robots, sort of... - jvriezen [more]
Unread 24-02-2004, 17:41
Arrowsmith Arrowsmith is offline
Turbocharged Reject
AKA: Mark Arrowsmith
#0382 (EA Team (Subject to Change...A lot))
Arrowsmith will become famous soon enoughArrowsmith will become famous soon enough
Send a message via ICQ to Arrowsmith Send a message via AIM to Arrowsmith Send a message via Yahoo to Arrowsmith
Serious OI problems
When it came time to power up the bot, we ran into a serious problem with the OI. For some reason, both radios flash on standby, with no data transfer between the OI and RC. In fact, with the exeption of the power light, none of the lights on the OI light up during startup. Did any of you run into this?
"Hey Mark, while you're out scouting, tell the other teams our robot has a Flux Capacitor"
"No. Even if we did, we lack both the plutonium power supply and the motors necessary to reach the 88 mph requirement for time travel. Besides, the Infinite Improbablility Drive is way cooler than the Flux Capacitor."
(commence 20 min argument)
Unread 24-02-2004, 20:18
Re: Serious OI problems
I believe you need to set the team number by tethering first, before the OI and RC will communicate by radio.
Unread 29-02-2004, 22:31
Turbocharged Reject
we did all that. It was working before, but it isnt now.
Unread 04-03-2004, 09:27
HuskieRobotics HuskieRobotics is offline
HuskieRobotics has a little shameless behaviour in the past
Did you use the dashboard program to see if the 2 signals numbers were the same???
Unread 04-03-2004, 16:43
Turbocharged Reject
The dashboard isn't recieving any information either. The connection times out every time we plug it in.
Unread 04-03-2004, 17:19
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Hmm, how about fuses? I forget if they replaced them with self-resetting circuit breakers this year... but if they haven't, check the fuse.
Chopsaw? Chopsaw.
Unread 04-03-2004, 17:45
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
I would suggest calling IFI if you can't solve this in a few days - some of the lights should light up. For example, the radio lights and backup battery lights and such.
Unread 10-03-2004, 14:28
Turbocharged Reject
After trying three times to call IFI, we learned that the processor in the oi was blown. this is unfortunate, as we are going to the Pittsburgh regional tomarrow. Hopefully we can get a replacement overnighted to the Events Center. Thanks for your help.
Unread 10-03-2004, 14:36
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Did you "upgrade" to the new IFI firmware and loader? We had a similar problem after "upgrading". The default code would work, but all of our other code (that was working with the old firmware and loader) would just hang up. We wasted 6 hours at VCU trying to figure this out. The big problem turned out to be the loader.
Be forwarned that the new upgrades may have unexpected affects on your code. One example: at the beginning of autonomous mode, our gearboxes would shift into neutral (and then we couldn't get them into gear in auto-mode since we can't shift on the fly). This resulted in us sitting still for almost all of our autonomous periods. We finally found the problem after our last match of the regional, but the root cause was the new firmware slightly changed the way the servos worked (of course, everything worked just fine with the old firmware).
Anyway, the point is: beware of the upgrade.
IFI Loader problems billstu Programming 22 23-03-2004 11:39
servo problems lpramo55 Programming 5 20-01-2004 22:23
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
