Go to Post :D NASCAR is way harder than we thought. - SL8 [more]
Unread 24-02-2004, 20:27
HuskieRobotics HuskieRobotics is offline
HuskieRobotics has a little shameless behaviour in the past
Can You help us???
We would like to know a few things. First, Are there any default variables that we can use?? if so what are they?? Second, Where are all of the variables for the program defined??? Thanks!!
Unread 24-02-2004, 21:19
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Re: Can You help us???
besides the control variables ( that should only change loop-to-loop ) first has not made you any variables. you put any variables you want in the user_routines.c file in the section right under where it sais
/*** DEFINE USER VARIABLES AND INITIALIZE THEM HERE ***/
/* EXAMPLES: (see MPLAB C18 User's Guide, p.9 for all types)
unsigned char wheel_revolutions = 0; (can vary from 0 to 255)
unsigned int  delay_count = 7;       (can vary from 0 to 65,535)
int           angle_deviation = 142; (can vary from -32,768 to 32,767)
unsigned long very_big_counter = 0;  (can vary from 0 to 4,294,967,295)
and if you wana get realy fancy ( which i dont think, from this post, you are too intrested in ) you can go into the user_routiens.h file and do typedefs... etc but if you wana declare a counter variable, say, you would simply put
unsigned counter1 = 0;
and there ya go. simple eh? theres a bunch of variable types, im not even gonna start goin there. good luck guys
"You're not a real programmer until all your sentences end with semicolons;"
