Go to Post When FIRST teams are as numerous and as well supported as basketball teams, we will know that our culture is preparing young people to compete in the 21 st century and we are spending our 2 million minutes wisely. - N7UJJ [more]
Unread 25-02-2004, 16:16
Jared Stofflett Jared Stofflett is offline
Jared Stofflett is an unknown quantity at this point
Send a message via AIM to Jared Stofflett
Default mapping relay questions
I'm still not extremely comfortable looking through the code. From what I've found relay1 and relay2 are mapped for joystick drive to limit movement. Is this true in both single and double joystick mode? If it is it explains why my code isn't working and we need to rewire the spikes for the pneumatics. Appreciate any info, the section of code I found that made me think this is below.
* This default code maps the joystick buttons to specific relay outputs.
* Relays 1 and 2 use limit switches to stop the movement in one direction.
* The & used below is the C symbol for AND
relay1_fwd = p1_sw_trig & rc_dig_in01; /* FWD only if switch1 is not closed. */
relay1_rev = p1_sw_top & rc_dig_in02; /* REV only if switch2 is not closed. */
Unread 25-02-2004, 19:06
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Re: Default mapping relay questions
relay1_fwd/rev refer to relay positions, not going forward or reverse on drive one. These relays in general control spikes which in turn usually control solenoids. This is so you can send the solenoid in both directions to send the piston both ways. I, myself, just deleted the code limiting relay inputs. Anyways, to get back on topic, this should not be limiting your joysticks and drives, or anything on victors. Could you post your code so someone could look over it?
-Kesich
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
3 Questions!!! Final Standings! Andy Grady General Forum 1 22-02-2004 22:32
3 Questions!!! (2/20/04) Andy Grady General Forum 20 20-02-2004 17:31
3 Questions!!! (2/5/04) Andy Grady General Forum 11 05-02-2004 21:14
pre-inspection preparation questions Adams High Man OCCRA 7 22-10-2002 22:22
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
