Go to Post The fact the FIRST knows no boundaries, either geographic or cultural, is certainly one of our strongest assets as we move toward a changed culture. - Rich Kressly [more]
Unread 25-02-2004, 17:42
AntmanIV AntmanIV is offline
#1089 (Team Mercury)
AntmanIV is an unknown quantity at this point
Send a message via AIM to AntmanIV
3 joysticks - port mirror Q
Does anyone know how to disable the port mirroring so we can use more than two joysticks at a time?
Saru mo ki kara ochiru. --
Even monkeys fall from trees. or
Anyone can make a mistake.
What do bananas smell like?
Unread 25-02-2004, 17:58
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: 3 joysticks - port mirror Q
Port Mirroring? If you are refering to pins 15, 8, 9, and 5, Don't worry about it. On p1 and p3, they're LED drivers, and on p2 and p4, they're second ins for p3 and p1, respectively. The default code guide gives the pin guides.
need joysticks! Tom Bottiglieri General Forum 14 24-02-2004 09:36
More than one joystick from one port Jmoo Programming 3 26-06-2003 18:01
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
