we need to know where the sensor wires need to be placed and how to program it
we also need to know the degrees of the sensor too for positioning Last edited by HuskieRobotics : 03-03-2004 at 15:09. |
Re: wiring and installing a sensor
what kind of sensor?
the kind we need for following the white line
its also a banner brand Last edited by HuskieRobotics : 03-03-2004 at 13:43. |
brown wire - this is the postitive. connect it to +12V blue wire - this is the negitive. connect it to ground (on the battery) black wire - N.O. wire white wire - N.C. wire you then can choose between N.O. and N.C. (it REALY doesnt matter). you connect the one you choose to the digital in. for our sake, were gonna say you plug it into digital input 10. now to code it, in the code first you have to set it as an input. this is done for you in the default code: Code:
digital_io_10 = 1; Code:
if(rc_dig_in10 == 1) {
//do this if its ON
} else {
//do this if its OFF
Thank you!!!!!
the banner sensors are little yellow boxes with a red lens - they send out a pulsed infrared light, and look for it to be reflected back - usually the carpet will not reflect it, but the tape or white paint will
the little sensors FIRST gave us that are about a 1/4" square with three leads are infared recievers that are designed to pick up the beacon from the center of the field - there is a whole page of stuff on those on the innovationfirst.com website - under FIRST robotics / documents / beacon section they are a little more complicated - you pretty much need to wire them to rc_dig_in_01 or 02 and use the interrupt flags to detect when they change state - also they need to be enclosed because they will pick up the IR signal from almost all directions the way they are. |
#8
Hello,
Can someone please kindly tell me if last year's banner sensors are allowed in this years competition THnx |
#9
yes they are
#10
