Go to Post GP is an ideal to live by, but not a tool to judge with. - Rich Kressly [more]
Unread 03-03-2004, 17:44
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Pressure Switch: Ordering a Spare
Can someone please verify if this is the pressure switch http://www.nasonptc.com/switch_sm.htm. If it isn't could you please point me in the right spot, we'd really like to get a few more. I searched and couldn't find anything in another thread.
Unread 22-03-2004, 19:15
Robohawk-master's Avatar
Robohawk-master Robohawk-master is offline
AKA: Barry
#1109 (Robohawks)
Team Role: Operator
Robohawk-master is on a distinguished road
Re: Pressure Switch: Ordering a Spare
Isn't the pressure switch a Texas Instrament this year? If not check the product name and its # go to the vendors site and punch it in, if they wont let you order it there you can at least look for a local retailer
- Barry -
-2004 Canadian Regional Semi-Finalists
-2004 Bruce Power Safety Award
Unread 22-03-2004, 19:17
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
No the TI item is the pressure transducer. I will try to get a art number and retailer for the preesure switch that shuts off the compressor at 120psi and on at 95psi. Thats what you are looking for correct?
-Michael Dessingue
Unread 22-03-2004, 19:19
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Team Role: Electrical
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
The texas intruments thing is to check how much pressure is left in the tanks. The one he is talking about is the one that turns off the compressor when it reaches 120 psi. I know because we had it wired wrong. When you wire it make sure that the compressor is connected directly to the spike relay and that the pressure switch is connected into a digital i/o on the rc. Looks the same besides the color.
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 22-03-2004, 20:15
you may not need this but what you would want to do to program that is:
1)connect one terminal to the ground on the digital in, the other to SIG
2)Wire your compressor up on a Spike
3) *Optional* In the code, set macros for the dig in (ex CompSwitch) and the relay out(ex Compressor)
4) Write code
if(!CompSwitch)
     Compressor = 1;
else
     Compressor = 0;
Pressure switch code kingpin3787 General Forum 11 22-02-2004 21:52
connecting pressure switch kingpin3787 Pneumatics 2 19-02-2004 21:01
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
